Topic: Cant bootload ATMEGA328PU-TH (Read 123 times) previous topic - next topic
RyanAES
So i am at my wits end with this as i have never had problems with boot loading before.. I made some pcbs with the chip on the subject title above and cant for the life of me upload a bootloader via arduino as isp.
I am using an arduino nano in order to do this but i get an error even when using minicore, I posted similar subject on the wrong thread so hopefully i wont get in to bother for this, Anyway this is the chip that is currently on my board:
https://lcsc.com/product-detail/ATMEL-AVR_ATMEL_ATMEGA328P-AU_ATMEGA328P-AU_C14877.html.
I have never used these chips before as i am used to the chips on the uno ATMEGA328P U.
Whatever the difference between these two microcontrollers i just cant seem to boot load the AU version successfully!
I decided to test each pcb against each other and found two of the pcbs had 5 volts coming from the MOSI pin of the microcontroller so decided to sit those to the side although i still cannot upload the bootloader successfully, I decided to order another version the atmega chip ATMEGA328-AU which is without the P, Could it be the chips themselves due to having different signatures? I will post a picture of my schematic below which also could be the error.
ERROR:
Code: [Select]
Arduino: 1.8.13 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\RyanA\Downloads\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr/bin/avrdude -CC:\Users\RyanA\Downloads\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\RyanA\Downloads\arduino-1.8.13-windows\arduino-1.8.13\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0xffff00
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
PaulRB
You have a second SPI device on the bus (mcp2515) and it's chip select is controlled by an atmega pin, which will be floating, there is no pull-up/down resistor there that I can see. So could the mcp chip be  interfering with the bus?
markd833
Have you taken onboard the suggestions from your other thread?
I would suggest you implement what was advised in #1 and #2 as a starter.
I'm guessing (judging by the value that you've assigned to it) that the component L1 between the RESET and VCC was meant to be a resistor, rather than an inductor?
In the designs I've seen, AREF generally has a 100n capacitor to GND.
ShermanP
You will not want to use the 328.  The 328P (the one in your link) is the right one, and it's the one found on the Uno, Nano and Pro Mini.  From other threads, it's not clear the Arduino IDE will even work as is with the 328.
Have you made sure your Uno as ISP will successfully flash a bootloader to something else?
PaulRB
Yes, it works fine. You can select 328 or 328P with minicore.
But changing to use 328 instead of 328P will not help the OP. The problem for the OP is jumping into the deep end of the pool before learning to swim.
