Topic: water level/ wave height measuring device (Read 211 times) previous topic - next topic
Andrew530
i am trying to make a device to measure water level and wave height with a nano 33 iot and a maxbotix mb7060-100 xl.  i want it to every 10 min or so take a few readings, record the min/max (to determine the height) and average and write it to a text file on a computer via wifi if possible.
jimLee
Where (on the planet) are you located?
-jim lee
PNW Ardiuno & Maker club
1012 9Th Street, Anacortes, WA 98221 (Around the back of building)
GITHUB -> https://github.com/leftCoast
horace
martinius96
I have done similar project based on Arduino / ESP8266 / ESP32 with ultrasonic sensors HC-SR04 or its waterproof version JSN-SR04T.
It is sending measurement to database each 10 minutes and then it is going to sleep.
Based on webapp, value from sensor is calculated, because higher water level = less measured distance between sensor and water level. And also result value and with known diameter of waterwell I can calculate value to volume in liters...
Webapp have many features, for instance line graphs with vizualization in time for 24 hours, 7 days. Via gauges I can visualize TOP max / min values for 24 hours, 7 days, 30 days.
Webapp is right now fully translated to languages:
  • Slovak
  • German
  • English
  • Russian
If interested: martinius96@gmail.com
Arduino and website programmer
