Topic: Interested in Automating Ikea Wall Table.  (Read 281 times) previous topic - next topic
jarduinohome
Hello everyone,
I'll be using 2 IKEA wall mounted tables. I need a simple solution to open/close them using a physical button.
The amount of force needed to lift the table & slide the support in place is minimal so I believe a servo motor could be useful.
What do you all think?/Has anyone worked on something similar?
Are there local hobbyist in cities that might be able to lend a hand with this project?
https://www.ikea.com/us/en/p/-wall-mounted-drop-leaf-table-brown-black-80217524/
https://www.youtube.com/watch?v=rRH79MjBjiY
Thanks!
zwieblum
Get a scale, measure the force you need to open the thing - it'll most likely be a bit greater than you think.
jarduinohome
That's a good point. Thank you for sharing that. Do you have any thoughts on what would be good for lifting something this heavy?
zwieblum
Quick & Dirty: string, levers, geared motot + 2 endswitches.
small & beautiful: same stuff used to open windows.
cedarlakeinstruments
If you use a linear actuator like the ones from Progressive Automations, you won't need anything other than a power supply and an on/off switch: they will stop at end of travel.
Electronics and firmware/software design and assistance. No project too small
