Topic: [Solved] Where should I put the flyback diode? (Read 585 times) previous topic - next topic
cdb101
Oct 08, 2020, 05:54 pm Last Edit: Nov 08, 2020, 03:17 pm by cdb101
This setup use  a dual channel relay to forward and reverse a 12 volts DC motor (air pump). When both relay are low, both DC motor pin are at ground level and the motor is idle. When channel 1 is high and channel 2 is low, the motor pump forward while when channel 1 is low and channel 2 is high, the pump work backward. If both channel are high.... It move into trouble zone (so better not going there)!
It work for months but I do not have flyback diode and one of my system failed on the long run. The relay leak current on the signal pin. Instead of reading 0 volt and 5 volt on low and high state, I read 2.6 volt when nothing is connected on both signal pins. Because of this, both channel read a High state and my battery (and fuse) short to ground. I assume the spike current without the flyback diode did this?
Since power is reverse from time to time in my setup, where should I put the flyback diode and what orientation will it require?
This is the relay I use. There is 2 diodes on the board but I don't know if it is for protection?
larryd
#1
Oct 08, 2020, 06:19 pm Last Edit: Oct 08, 2020, 06:20 pm by larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
dlloyd
Quote
Uhm, this sounds normal. The control circuit has a current limiting resistor, a visible red LED and an IRLED connected in series, so with nothing connected, 2.6V sounds correct. Did you know that as a test (with Arduino control outputs disconnected), you could just short any relay input to GND to activate it?
Smajdalf
What trouble? It should be OK writing both HIGH.
cdb101
Yes and no. While troubleshooting I just encounter this "feature". On my setup, the trigger pin are connected to 0volt for most of the time and in this state the relays are not activated unless I turn the control pin high (+5volts). So for me this is new because the relay was not activating when connected to a low state or ground before. I have 3 identical systems and they are working well for over 3 months now. Out of 3, only one failed not long ago. I really want to understand what happened to correct the other system at the same time.
It's like the fail relay have invert is reaction to my high and low controller state.
When connected to a low state (common Gnd or low state pin), the relay activate (the led turn on and the spst switch). When my controller go in the high state (+ 5Volt), the relay deactivate (the led turn off and the spst switch back) while I expect it to activate!  I suspect the flyback diode but it can be something else? Your answer make my doubt.
yes you are right. my mistake.
cdb101
You are right and this mean that my two blowned fuse blows for another reason! Somehow, my dual channel relay shorted my 12 volts to ground twice in a row. But my wiring (and the schematic) normally cannot result in shorthing 12 volt to ground. It is somewhere else.
Now that I have dismounted the relay and test it separetly, the output do not short again. I mounted it back and it work. aarghhhh! Nevertheless, the relay behave the opposite I expect. It is activated when connected to low state and deactivate when turn to high state. The opposite of the other relays I have in my setup.
larryd
Contacts 'can' weld momentarily (then open); if this occurs you have a short between 12v and GND.
You do have a fuse ;).
No technical PMs.
Paul__B
And a common bridge rectifier fills the bill admirably.
But this is on the motor side, and there seems to be some significant confusion about the operation of the control side of the relay module which is "active low".   In any case, no malfunction of the control circuit can cause the motor side to short out if correctly wired as described; it would have to be a contact problem in the actual relays.
cdb101
Yes "active low" is the part I missed out! And I still don't figure out how I miss this one.
Probably because my system behave has expected when I test it.
I will go the common bridge rectifier for sure. Any general diode such has 1N4148 will do the job?
It is only a 12 watts pump.
thank you
larryd
1N4000 - 1N4007 would probably work.
No technical PMs.
cdb101
I tried the common bridge rectifier with a W10M with no success. There is 4 pins on the W10M.
I figured out the pinout with a multimeter + google + datasheet.
In my initial setup, I use the 2 channel relay to invert the power supply. 1 state = +12 volt , GND the other state = GND , + 12volts. If I do this with the W10M, the output voltage don't change direction. It is always 12volt. Not what I want.
In the schematic with the common bridge, It seem that the switch don't invert the voltage anymore but act by bypassing some diode thus applying 12 volts and GND at different point on the W10M. Is this a correct understanding?  Can someone help with this?
thank you
cdb101
#11
Nov 05, 2020, 07:41 pm Last Edit: Nov 05, 2020, 07:53 pm by cdb101
I tried with stand alone diode and it work. I rewired the W10M like this:
W10M +  to 12 volts
W10M D to GND
W10M B to + Motor
W10M C to - Motor
Now since my switch relay apply 12 volts on B pin of W10M while C pin is grounded
OR
apply 12 volts on the C pin while B pin is grounded.
Do I really need to connect thje W10M + pin to 12 volts and D pin to ground?
Precison:
The switching still work when I disconnect the + pin and the GND pin but will the Flyback protection will be active?
thank you
Paul__B
Of course not!
The "+" on the bridge goes to your positive supply, the "-" to your negative.  The two "~" go to the motor.  Connecting the bridge to the circuit should not cause any discernible difference; it is there for protection only.
Note that the common W04/ W10 or 1N400x diodes are not appropriate for use with PWM.
cdb101
Then I don't understand. Based on this 4 scenarios, I tried to understand where the flyback diode actually help and could'nt. What I miss?
Top left, both relay and motor pin are grounded.
Top rigth, 1 relay activate and the motor run forward.
Second left, the expected flyback current when the switch is turn off. At this point (and this is not the case with the typical scenario on internet) the + and - side of the motor are both connected to ground. If the flyback current want to flow. It should.
Third left. I don't understand the top diode. For me the only thing it do is to allow high voltage to flyback in my power supply.
MarkT
#14
Nov 06, 2020, 12:47 pm Last Edit: Nov 06, 2020, 12:48 pm by MarkT
The freewheeling diodes come into play when the switches go off.  They are the only possible routes
then for any current that's flowing in the inductive load, and steer that current to the supply & ground.
The switches always have to turn off before others turn on, else there is a direct short to ground
from the supply.  Thus you have to deal with the current during that short bit of "deadtime".  If
you don't deal with it, the inductance will instantly jump the voltage to whatever level is necessary
to force the current through the circuit, damaging semiconductors.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
