Topic: l298n module to control 4 fuel injectors (Read 99 times) previous topic - next topic
Fouad19764
Hi to all,
plan to buil fuel injector tester,so in order to control them via arduino and l298n module.
the question ,it is posible to connect injectors to ground and the other pin to l298n
injector 1 out1
injector 2 out2
injector3 out3
injector4 out4
the code part should be easy.
thanks
groundFungus
Google "Arduino injector tester" to see what others have done.  My opinion is that there are better ways to drive injectors than the ancient L298 crappy motor driver.
You will save everyone's time if you read and follow the forum guidelines.  :)
https://forum.arduino.cc/index.php/topic,148850.0.html
and
https://forum.arduino.cc/index.php?topic=97455.0
jremington
#2
Oct 10, 2020, 05:38 pm Last Edit: Oct 10, 2020, 05:38 pm by jremington
Quote
Yes. The L298N will be useful only if the injectors draw less than 1 Ampere each. Otherwise it may overheat and shut down.
