Topic: how can i get an uno to control a 12v device (Read 1 time) previous topic - next topic
volt64bolt
so i need the arduino to power on a 12v fan then a 12v peltier then power off the peltier and then the fan with controllable delays, i should be able to do the code but i don't know if it will be able to run the 12v devices as it says it has a 5v operating power? i am ok with code but have no clue about hardware, i just wanted to know if i needed a different board or extra stuff before i ordered
emre_mutlu
Use an NMOS to drive the Load. Look for IRF1010E or similar it should do the job. You should check the Gate Threshold voltage, it has to be smaller than 5V.
Best regards,
Emre
noiasca
use a relay board. They come in different variants with 1, 2, 4, 6, 8, 16 relays on one module.
how to react on postings:
- post helped: provide your final sketch, say thank you & give karma.
- post not understood: Ask as long as you understand the post
- post is off topic (or you think it is): Stay to your topic. Ask again.
- else: Ask again.
