Juraj:
and your recommendation where to store the supplied ssid and password?
or how to store it in the crypto chip available on 'nina boards'?
I am actually still investigating this. As I started to develop the library I though that I would store this in the EEPROM, but neither the Nano 33 IoT nor the MKR 1010 have one (I figured afterwards). So I'll be investigating the crypto chip as you mention. Thanks!
or WiFiNINA library has storage functions, which store data on esp32 flash.
and of course it is possible to store data in flash of the SAMD with EEPROM emulation library or directly
Juraj:
Looking the reference page of the library, I don't seem to identify which functions are the ones to store data in the esp32 flash. Could you point out to these functions, please?
Thanks.
gdeflaux:
Thanks.
I've tried to use the example provided on Wifi Storage without success. Nothing seems to get written to the storage.
I've noticed that the firmware version of the library (1.4.1) is higher than the one on my Arduino Nano (1.3.0). Could that be the issue? I can't update the Nano beyond the v1.3.0 with the Arduino IDE... That's the only thing that I can think of at this point.
I have no idea whether the firmware version is in any way related to your problem, though I do know that OTA features have been added to it in the recent releases.
If you do want 1.4.1, an easy way to get it is to install the hourly build of the Arduino IDE:
It doesn't mean you need to switch permanently to using the hourly if you don't like (it's primarily intended for beta testing), but you can just use it once in order to update your firmware, then delete it if you wish.
pert:
If you do want 1.4.1, an easy way to get it is to install the hourly build of the Arduino IDE: https://www.arduino.cc/en/Main/Software#hourly
That did it! I was able to flash the 1.4.1 firmware on the Nano with the hourly build of the IDE and the storage function seems to work fine now. I'll work on adding the storage of credentials to the provisioning library and report back. Thanks a lot for the tip!
gdeflaux:
the esp8266 WiFiManager can be used to add other parameters for user to set on the page, for example auth tokens for cloud services
I've updated the library. The credentials storage works fine and you can now specify an auth/api key if needed (thanks @Juraj for the idea). The README is also up to date.
