So I have an MKRZERO and I tried the simple blink sketch, which works fine. But than I tried to log some data over Serial. I used this Sketch:
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
Serial.println("Hallo");
In Theory it should print "Hallo" every 2 seconds. After it uploads it changes its port like all mkr ports, but when I tr to open this port it says: (Port busy). But there is no other service using this Board.. I checked with Windows process Explorer. (The Blink Sketch still works)!
I already:
restareted my computer
deleted all hidden Ports and reinstalled them
change Pc ports
Also I think it has something to do with my PC setup because it worked on a friends Laptop! I use Windows 10 with Arduino 1.8.13
Also after Uploading I have to double click the reset button to upload again. Is this normal? Shouldnt it switch automatically to bootloader?
Thanks for the Help!
