Topic: Adafruit Neopix strip matrix with text input via nRF 8001 BLE - not displaying. (Read 33 times) previous topic - next topic
fixedcoil
I am using a Leonado and trying to recreate the Adafruit GuggenHat project in a ZIGZAG matrix (48 x 10). I have taken the project sketch and modified it for my matrix but it does not display anything. Adding a debug Serial.print() following the matrix.print() shows the text from my phone (using the Adafruit UART app) is being received. Here is the modified sketch:
Code: [Select]
  GUGGENHAT: a Bluefruit LE-enabled wearable NeoPixel marquee.
  Requires:
  - Arduino Micro or Leonardo microcontroller board.  An Arduino Uno will
    NOT work -- Bluetooth plus the large NeoPixel array requires the extra
    512 bytes available on the Micro/Leonardo boards.
  - Adafruit Bluefruit LE nRF8001 breakout: www.adafruit.com/products/1697
  - 4 Meters 60 NeoPixel LED strip: www.adafruit.com/product/1461
  - 3xAA alkaline cells, 4xAA NiMH or a beefy (e.g. 1200 mAh) LiPo battery.
  - Late-model Android or iOS phone or tablet running nRF UART or
    Bluefruit LE Connect app.
  - BLE_UART, NeoPixel, NeoMatrix and GFX libraries for Arduino.
  Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
  MIT license.  All text above must be included in any redistribution.
  Modified to display on a 48 x 10 zigzag matrix.
#include <SPI.h>
#include <Adafruit_BLE_UART.h>
#include <Adafruit_NeoMatrix.h>
#include <Adafruit_GFX.h>
// NEOPIXEL STUFF ----------------------------------------------------------
// Intended for use with a flat zigzag panel 48 x 10 Neopixels.
#define NEO_PIN     6 // Arduino pin to NeoPixel data input
#define NEO_WIDTH  48 // Hat circumference in pixels
#define NEO_HEIGHT 10 // Number of pixel rows (round up if not equal)
//#define NEO_OFFSET  (((NEO_WIDTH * NEO_HEIGHT) - 240) / 2)
// Set up the matrix
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(48, 10, NEO_PIN,
                            NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT +
                            NEO_MATRIX_ROWS + NEO_MATRIX_ZIGZAG,
                            NEO_GRB            + NEO_KHZ800);
char          msg[21]       = {0};            // BLE 20 char limit + NUL
uint8_t       msgLen        = 0;              // Empty message
int           msgX          = matrix.width(); // Start off right edge
unsigned long prevFrameTime = 0L;             // For animation timing
#define FPS 20                                // Scrolling speed
// BLUEFRUIT LE STUFF-------------------------------------------------------
// This is how the nRF8001 is wired to the Leonado board
// CLK, MISO, MOSI connect to hardware SPI.  Other pins are configrable:
#define ADAFRUITBLE_REQ 10
#define ADAFRUITBLE_RST  9
#define ADAFRUITBLE_RDY  2 // Must be an interrupt pin
Adafruit_BLE_UART BTLEserial = Adafruit_BLE_UART(
                                 ADAFRUITBLE_REQ, ADAFRUITBLE_RDY, ADAFRUITBLE_RST);
aci_evt_opcode_t  prevState  = ACI_EVT_DISCONNECTED;
// STATUS LED STUFF --------------------------------------------------------
// The Arduino's onboard LED indicates BTLE status.  Fast flash = waiting
// for connection, slow flash = connected, off = disconnected.
#define       LED LED_BUILTIN    // Onboard LED (not NeoPixel) pin
int           LEDperiod   = 0;   // Time (milliseconds) between LED toggles
boolean       LEDstate    = LOW; // LED flashing state HIGH/LOW
unsigned long prevLEDtime = 0L;  // For LED timing
// UTILITY FUNCTIONS -------------------------------------------------------
// This bit is not relevant as we are usig a flat panel.
// Because the NeoPixel strip is coiled and not a uniform grid, a special
// remapping function is used for the NeoMatrix library.  Given an X and Y
// grid position, this returns the corresponding strip pixel number.
// Any off-strip pixels are automatically clipped by the NeoPixel library.
// uint16_t remapXY(uint16_t x, uint16_t y) {
//  return y * NEO_WIDTH + x - NEO_OFFSET;
// Given hexadecimal character [0-9,a-f], return decimal value (0 if invalid)
uint8_t unhex(char c) {
  return ((c >= '0') && (c <= '9')) ?      c - '0' :
         ((c >= 'a') && (c <= 'f')) ? 10 + c - 'a' :
         ((c >= 'A') && (c <= 'F')) ? 10 + c - 'A' : 0;
// Read from BTLE into buffer, up to maxlen chars (remainder discarded).
// Does NOT append trailing NUL.  Returns number of bytes stored.
uint8_t readStr(char dest[], uint8_t maxlen) {
  int     c;
  uint8_t len = 0;
  while ((c = BTLEserial.read()) >= 0) {
    if (len < maxlen) dest[len++] = c;
  return len;
// MEAT, POTATOES ----------------------------------------------------------
  matrix.begin();
  // matrix.setRemapFunction(remapXY);
  matrix.setTextWrap(false);   // Allow scrolling off left
  matrix.setTextColor(0xF800); // Red by default
  matrix.setBrightness(31);    // Batteries have limited sauce
  BTLEserial.begin();
  pinMode(LED, OUTPUT);
  digitalWrite(LED, LOW);
  unsigned long t = millis(); // Current elapsed time, milliseconds.
  // millis() comparisons are used rather than delay() so that animation
  // speed is consistent regardless of message length & other factors.
  BTLEserial.pollACI(); // Handle BTLE operations
  aci_evt_opcode_t state = BTLEserial.getState();
  if (state != prevState) { // BTLE state change?
    switch (state) {       // Change LED flashing to show state
      case ACI_EVT_DEVICE_STARTED: LEDperiod = 1000L / 10; break;
      case ACI_EVT_CONNECTED:      LEDperiod = 1000L / 2;  break;
      case ACI_EVT_DISCONNECTED:   LEDperiod = 0L;         break;
    prevState   = state;
    prevLEDtime = t;
    LEDstate    = LOW; // Any state change resets LED
    digitalWrite(LED, LEDstate);
  if (LEDperiod && ((t - prevLEDtime) >= LEDperiod)) { // Handle LED flash
    prevLEDtime = t;
    LEDstate    = !LEDstate;
  // If connected, check for input from BTLE...
  if ((state == ACI_EVT_CONNECTED) && BTLEserial.available()) {
    if (BTLEserial.peek() == '#') { // Color commands start with '#'
      char color[7];
      switch (readStr(color, sizeof(color))) {
        case 4:                  // #RGB    4/4/4 RGB
          matrix.setTextColor(matrix.Color(
                                unhex(color[1]) * 17, // Expand to 8/8/8
                                unhex(color[2]) * 17,
                                unhex(color[3]) * 17));
        case 5:                  // #XXXX   5/6/5 RGB
            (unhex(color[1]) << 12) +
            (unhex(color[2]) <<  8) +
            (unhex(color[3]) <<  4) +
            unhex(color[4]));
        case 7:                  // #RRGGBB 8/8/8 RGB
                                (unhex(color[1]) << 4) + unhex(color[2]),
                                (unhex(color[3]) << 4) + unhex(color[4]),
                                (unhex(color[5]) << 4) + unhex(color[6])));
    else { // Not color, must be message string
      msgLen      = readStr(msg, sizeof(msg) - 1);
      msg[msgLen] = 0;
      msgX        = matrix.width(); // Reset scrolling
  matrix.fillScreen(0);
  matrix.setCursor(msgX, 0);
  if (--msgX < -55) {
  matrix.show();
  delay(150);
  if ((t - prevFrameTime) >= (1000L / FPS)) { // Handle scrolling
    matrix.print(msg);
    Serial.print(msg); // Debug print
    if (--msgX < (msgLen * -6)) msgX = matrix.width(); // We must repeat!
    matrix.show();
    delay(150);
    prevFrameTime = t;
To check that I had not made a wiring error on my panel I used this sketch, modified for my layout:
https://create.arduino.cc/projecthub/gatoninja236/how-to-make-a-neopixel-matrix-3f5631 and it displays as expected.
Both use the Adafruit Neopixel libraries and matrix.print() and while the code differs so far as I can tell they both do the same with respect to the matrix functions. I'd be grateful if anyone can give me an idea as to where my problem lies.
