Topic: MKRZERO maximum Vin rating (Read 1 time) previous topic - next topic
MicheleMaris
Dear All,
I would like to supply power to an MKRZero through the Vin using 4
AA cells.
The maximum theoretical voltage (with new cells) would be 6 volts.
I looked at the MKRZero web page,
https://www.arduino.cc/en/Main/ArduinoBoardMKRZero&
it rated Vin between 5 and 6 V.
So it seems there would be no problems.
However at the end of the web page it is stated "Please DO NOT POWER VIN with more than 5V."
So my question is: may I use up to 6V on Vin?
Thank you very much
Mic
CrossRoads
If you look at the schematic
https://www.arduino.cc/en/uploads/Main/ArduinoMKRZero-schematic.pdf
you'll see that Vin just goes thru a couple of MOSFETs and then is connected to 5V.
There is no regulator. Any external devices connected to the 5V pin will essentially see whatever is on Vin.
So I would limit Vin to 5V.
4 NiCads, or 4 NiMH would provide 4.8V and would be a safer option than 4 standard AAs, which could be higher than 6V total when fresh.
MicheleMaris
Ok thank you, I will try this way
M.
