I have an entry level but pretty decent 2-channel o'scope.
I think I might treat myself to a logic analyzer soon. (I should probably have bought that first, but too late now.) Does anyone have any recommendations on a decent brand/model for the hobbyist? (Recommendations could also include "don't touch with a bargepole".)
Quite a few years back I took the plunge and bought a LogicPort usb LA from pctestinstruments.com and that has served me well. It's probably OTT for what I need now but it works.
The supported software level is mentioned in a rather confusing way. 1.2.10 appears to work well.
You get only 4 "grabber" clips. I've added some more to my shopping list.
It is very useful and quite intuitive to use. 2 things to bear in mind:
you don't get a real time preview of the traces. You set a timer and start to capture, then you hunt for the desired section of the trace. Not what you are used to on an oscilloscope.
The display of timings on a wave form is generally good, but is not very flexible. If you need something like the timings of the start and end of a burst of data, then it becomes difficult. That is a minor issue, though.
For digital hobby electronics, this is more useful than an oscilloscope.
And a little tip, when using an LA and you can't seem to figure out the problem its definitely
doing a quick check with a 'scope that the signals are behaving properly as digital logic signals
a LA won't know if this is happening, and if so could read the signals differently from the
hardware you are debugging, leading to real confusion!
This sort of thing commonly happens when two outputs are shorted together, for instance.
