Topic: How long will a 1W LED last without a heat sink? (Read 357 times) previous topic - next topic
tperry724
Folks, got a project here that uses a 1W LED.  I've got a power supply adjusted to just over the forward voltage of the LED - about 3.7V.  The LED definitely runs warm/hot.  How long will it last without a heat sink attached?
Thanks,
Tony
missdrew
Anywhere from 1 second to forever. The datasheet MAY tell you. :)
srnet
Why dont you try it, in a suitable flameproof place of course ?
No PMs please, they dont get answered.
tperry724
Well, I'll just give it a go.  I bought the LEDs direct from China so no datasheet for these.  If it burns out, I'll find a heat sink around here and get some thermal glue.
Paul_KD7HB
Thanks,
Tony
The connections between the LED and the power are the heat sink in your case. There is always a heat sink. You may add other heat sinks by mounting the LED on a printed circuit board with large copper pads.
Paul
DVDdoug
#5
Nov 06, 2020, 04:53 pm Last Edit: Nov 06, 2020, 04:57 pm by DVDdoug
Quote
Does that mean you're using a regular power supply with no current control?
High power LEDs (1W or more) normally use a special constant current (or controlled current) power supply.
If you don't know what the current is, you could be way-more or way-less than 1W.
   It will probably last forever at 1/10th of Watt...   ;)  LEDs (like all diodes) are highly non-linear and small change in voltage makes a HUGE change in current.   On the other hand, with the proper constant-current power supply the voltage "magically" falls into-place.
With "regular little LEDs" we use a series resistor, and with a known-constant voltage drop across the resistor we can calculate/control the current.  You can use a resistor with high-power LED but it has to be a "high power" resistor (about the same wattage as the LED, depending on the voltage & current of course) and the resistor is wasting power & generating heat.
...Somewhat ironically, LEDs run a lot cooler than a regular light bulb of the same light output but an LED can't take anywhere the heat that a tungsten filament can take.  So, it it's running cooler but it still needs a heatsink.
tperry724
tperry724
Hi all.  The answer in my case is not long at all.  Ha.  Gonna need another solution.
Tony
SteveMann
Tony
And another LED.
show a picture of the LED. Is there a reason you can't use a heat sink?
Fritzing pictures are NOT schematics. I don't speak Fritzing.
Please do not ask for help by PM. I will not respond. If you need help, post a question on the appropriate forum.
Click on Add Karma if I helped you.
westfw
Quote
that's not going to work.  You need to limit the current.  Read some of the tutorials on LEDs (the same logic applies to 1W leds as to the normal 20mA LEDs, except that you design for a current of ~250mA to get the full watt.)
In the absence of a current limit, if the power supply voltage is slightly less than the actual Vf of the diode, you won't get much output, and if it's slightly more than the actual Vf, the diode will happily draw much more than 1W for as long as it lasts.
You should be safely able to drive a 1W LED with "small" currents (say, 0.3W @ ~100mA) for quite a while (but it wont be at maximum brightness.)
