Debug Termimal Output Samples
- The following is the sample terminal output when running example ISR_Timer_Complex_Ethernet on Arduino SAM-DUE using W5100 Ethernet to demonstrate the accuracy of ISR Hardware Timer, especially when system is very busy. The ISR timer is programmed for 2s, is activated exactly after 2.000s !!!
While software timer, programmed for 2s, is activated after 10.917s !!!. Then in loop(), it's also activated every 3s.
Starting ISR_Timer_Complex_Ethernet on SAM DUE
Version : 1.0.1
CPU Frequency = 84 MHz
Timer Frequency = 84 MHz
Using Timer(0) = TC0, channel = 0, IRQ = TC0_IRQn
Timer(0), us = 50000.00
ITimer attached to Timer(0)
[5] Getting IP...
[7] MAC: FE-8A-F1-EA-DE-82
_pinCS = 0
W5100 init, using SS_PIN_DEFAULT = 10, new ss_pin = 10, W5100Class::ss_pin = 10
W5100::init: W5100, SSIZE =4096
2s: Delta ms = 2000
2s: Delta ms = 2000
[7728] IP:192.168.2.134
[7728]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Arduino Due
[7732] BlynkArduinoClient.connect: Connecting to account.duckdns.org:8080
[7849] Ready (ping: 6ms).
IP = 192.168.2.134
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
blynkDoingSomething2s: Delta programmed ms = 2000, actual = 10917
2s: Delta ms = 2000
blynkDoingSomething2s: Delta programmed ms = 2000, actual = 3000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
11s: Delta ms = 11000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
- The following is the sample terminal output when running example ISR_16_Timers_Array on Arduino SAM DUE to demonstrate the accuracy and how to use 16 ISR Timers from just 1 Hardware Timer.
Starting ISR_16_Timers_Array on SAM DUE
Version : 1.0.1
Timer(0), us = 100.00
1s: Delta ms = 1006, ms = 1006
1s: Delta ms = 1000, ms = 2006
1s: Delta ms = 1000, ms = 3006
1s: Delta ms = 1000, ms = 4006
1s: Delta ms = 1000, ms = 5006
1s: Delta ms = 1000, ms = 6006
1s: Delta ms = 1000, ms = 7006
1s: Delta ms = 1000, ms = 8006
1s: Delta ms = 1000, ms = 9006
1s: Delta ms = 1000, ms = 10006
1s: Delta ms = 1000, ms = 11006
simpleTimer2s: Dms=2000, actual=11118
1s: Delta ms = 1000, ms = 12006
1s: Delta ms = 1000, ms = 13006
1s: Delta ms = 1000, ms = 14006
1s: Delta ms = 1000, ms = 15006
1s: Delta ms = 1000, ms = 16006
1s: Delta ms = 1000, ms = 17006
1s: Delta ms = 1000, ms = 18006
1s: Delta ms = 1000, ms = 19006
1s: Delta ms = 1000, ms = 20006
1s: Delta ms = 1000, ms = 21006
1s: Delta ms = 1000, ms = 22006
simpleTimer2s: Dms=2000, actual=11111
1s: Delta ms = 1000, ms = 23006
1s: Delta ms = 1000, ms = 24006
1s: Delta ms = 1000, ms = 25006
1s: Delta ms = 1000, ms = 26006
1s: Delta ms = 1000, ms = 27006
1s: Delta ms = 1000, ms = 28006
1s: Delta ms = 1000, ms = 29006
1s: Delta ms = 1000, ms = 30006
1s: Delta ms = 1000, ms = 31006
1s: Delta ms = 1000, ms = 32006
1s: Delta ms = 1000, ms = 33006
- The following is the sample terminal output when running example TimerInterruptTest on Arduino SAM DUE to demonstrate the accuracy and how to start/stop Hardware Timers.
Starting TimerInterruptTest on SAM DUE
Version : 1.0.1
ITimer0 attached to Timer(0)
Using Timer(1) = TC0, channel = 1, IRQ = TC1_IRQn
ITimer1 attached to Timer(1)
ITimer0: millis() = 1104, delta = 1104
ITimer0: millis() = 2104, delta = 1000
ITimer0: millis() = 3104, delta = 1000
ITimer1: millis() = 3111, delta = 3111
ITimer0: millis() = 4104, delta = 1000
Stop ITimer0, millis() = 5001
ITimer1: millis() = 6111, delta = 3000
ITimer1: millis() = 9111, delta = 3000
Start ITimer0, millis() = 10002
ITimer0: millis() = 11002, delta = 1000
ITimer0: millis() = 12002, delta = 1000
ITimer1: millis() = 12111, delta = 3000
ITimer0: millis() = 13002, delta = 1000
ITimer0: millis() = 14002, delta = 1000
Stop ITimer1, millis() = 15001
ITimer0: millis() = 15002, delta = 1000
Stop ITimer0, millis() = 15003
Start ITimer0, millis() = 20004
ITimer0: millis() = 21004, delta = 1000
ITimer0: millis() = 22004, delta = 1000
ITimer0: millis() = 23004, delta = 1000
ITimer0: millis() = 24004, delta = 1000
ITimer0: millis() = 25004, delta = 1000
Stop ITimer0, millis() = 25005
Start ITimer1, millis() = 30002
Start ITimer0, millis() = 30006
ITimer0: millis() = 31006, delta = 1000
ITimer0: millis() = 32006, delta = 1000
ITimer1: millis() = 33002, delta = 3000
ITimer0: millis() = 33006, delta = 1000
ITimer0: millis() = 34006, delta = 1000
ITimer0: millis() = 35006, delta = 1000
Stop ITimer0, millis() = 35007
