Let me preface by saying this is my first time working with arduino, and I am a mechanical engineer not EE, so while I have a good understanding of the basics, some of the advanced topics still evade me.
Short version: I am trying to run a DC stepper motor with an EasyDriver and Arduino off of 24VAC power supply.
I've attached a schematic (please excuse the drawing if I have used the wrong symbol etc. I tried my best not having made many in the past) but here is the verbal write-up:
There are three enclosures to the system - Enclosure 1 which houses the stepper motor, Enclosure 2 which houses the arduino, EasyDriver, AC-DC Conversion (buck converter, bridge rectifier, capacitor), and two SPDT toggle switches , Enclosure 3 which houses a 24VAC actuator. Enclosure 2 and Enclosure 3 are mounted together
The 24VAC actuator is an off-the shelf product and is just a 24VAC motor, capacitor, two limit switches and DPDT switch. One of the toggle switches in enclosure 2 controls the components in Enclosure 3. In one position, the AC motor spins until it hits a limit switch. Then when the toggle switches to the other position it reverses direction until it hits another limit switch.
The second SPDT toggle switch controls the stepper motor. In one position, the stepper motor rotates 180 degrees, then in the other position it rotates the other direction 180 degrees.
24VAC power is converted to DC using a bridge rectifier, capacitor, and a buck converter.
The DC toggle controls the DC half of the circuit pretty well (minus some coding issues). The AC toggle controls the AC half of the circuit perfectly. The issue I am having is that operation of the AC circuit also causes the stepper motor on the DC circuit to activate even when not called. There is some major interference occurring because I have deconstructed-reconstructed the wiring and everything multiple times. We have attempted a few solutions namely moving components around and the issue still stands:
1. Mount the arduino, buck converter, easydriver in Enclosure 1 leaving just a toggler and AC-DC conversion in Enclosure 2 - problem still exists (Enclosure 1 & Enclosure 2 are 15+ft away).
2. Use two separate power supplies. Not an option for us unfortunately.
3. Add some snubber circuits/diodes into the assembly to help reduce the noise. This is a leading option, but I am just not knowledgeable to spec all those myself.
Really just looking for some guidance and advice. I've learned a lot so far, but I've reached my limit on personal experience and research to make educated attempts at a solution from here.
