HARDWARE: Arduino MEGA1280 made by
www.arduino.cc and MEGA2560 r3 made by inland.
SCHEMATIC: Arduino Button Example found here:
https://www.arduino.cc/en/Tutorial/BuiltInExamples/Button Please note I attached an O Scope probe (Tektronix 2205 - yes its old but I got it for free from work) to Pin 13 and ground.
EXPECTED BEHAVIOR: When the button is pushed a square wave should get generated with a period of 2x "toggler_time" for "square_wave_counter" times. (Please see source code).
ACTUAL BEHAVIOR: On both Arduino boards (listed above), if I pressing the button right after uploading the code to the board the square wave forms instantly, if I press the button in short succession, everything is OK. However, if I upload the code and wait 10 seconds or longer or wait between pushing the button the O scope does not show a square wave rather it shows two lines. After pressing the button for a length of time (the longer the interval between pushing the button the long the length of time needed to push the button) the square wave finally starts. I attached screen shots from the O scope of the screen when no button is pressed, of the square wave and the problem state described here.
Any help would be greatly appreciated!
SOURCE CODE:
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
const long toggle_time = 1100; // toggle pin every X number of us (MICROSECONDS, square wave is 2x
int square_wave_counter = 1840; //square wave counter, has to start high to wait for pushbutton to zero it.
const int cycle_counter = 1840; //number of half cycles to run per each button push.
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
static long last_toggle; //microseconds counter
static int pin_state = LOW;
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
square_wave_counter = 0;
//create square wave is counter is below cycle_counter
if (((long) micros() - last_toggle >= toggle_time) && (square_wave_counter < cycle_counter)) {
pin_state = !pin_state; // invert pin state
digitalWrite(13, pin_state);
last_toggle += toggle_time;
square_wave_counter++;
} // if
if (square_wave_counter >= cycle_counter) {
digitalWrite(ledPin, LOW);
