Topic: Reprogramming the AAG RS485 Weather Station (Read 19342 times) previous topic - next topic
graynomad
so everything should go smoothly
He he.
______
Rob
EmilyJane
He he.
______
Rob
Yeah, that's the thought that went through my head, too. :)
Coding Badly
Bah.  You two are pessimists.  What could possibly go wrong?
An old boss helped design and build the control system for a very large tank farm.  While driving to the plant for the startup, he stopped at 7-Eleven and picked up a stack of job applications ... just in case things went poorly.
EmilyJane
:) Funny story.
If I didn't break anything and the schematic diagram is correct it really should go smoothly. With the FTDI bridge and a 16 MHz clock, it should look exactly like an Arduino NG with LEDs on every pin. :D
EmilyJane
Well, I've got an Arduino bootloader programmed into the AAG Atmega8 now and am just playing around with the on-board hardware. I'm programming it from the IDE through an FTDI USB/serial bridge with a 100nF capacitor from DTR to reset. The first thing I have noticed is that the schematic is wrong for P1, the photocell. On the schematic it should show R20 (3K0) and P1 reversed. The 3K0 resistor goes to Gnd and the photocell goes to +5 volts. If you're is playing along at home, you'll want to change your schematic. :)
EmilyJane
I had a chance to play with the weather station and wrote this code to set up the ports and get wind direction. I created an array of bytes to hold the 16 possible states of the Hall effects. Either one Hall effect is triggered or two are when the magnet is between two of them. The 16 states map into a string array that corresponds to the 16 directions.
Next I will get the 1-wire temperature working and wind speed and then it will be at the same point where I took it apart.
AAG wired the DS1850 directly into PD5 with no pull-up resistor so I'm going to re-wire it with one so I can have a proper 1-wire bus to extend outside the enclosure. I don't have too much flash so I'm going to have to work on the 1-wire code to make it as slim as possible.
PC0-PC5 PD6-PD7 = Q1-Q8  Wind Direction
PD5 = 1-Wire DS18B20
PD4 = Q9 Wind Speed
PD2 = DD RS485 Data Direction
PD1 = TXD
PD0 - RXD
ADC7 = P1 Photocell Schematic wrong actually pulls up to 5V
ADC6 = Voltmeter
#define ADC6  6
#define ADC7  7
const char* windDirection[16] = { // strings for the 16 wind directions
  "N", "NNE", "NE", "ENE", "E", "ESE", "SE", "SSE", "S", "SSW",\
  "SW", "WSW", "W", "WNW", "NW", "NNW"};
uint8_t WD[16] =  { // Hall effect outputs for 16 wind vane positions
  B01111111, B00111111, B10111111, B10011111, B11011111, B11001111,\
  B11101111, B11100111, B11110111, B11110011, B11111011, B11111001,\
  B11111101, B11111100, B11111110, B01111110};
uint8_t match_wind(uint8_t* mask_array, uint8_t mask){ // match wind direction mask with array of possibles
  for (uint8_t i=0; i<16; i++)
    if (*mask_array++ == mask)
      return i; // return match which corresponds to string array index too
  return 16; // signal no match.
uint8_t make_wind(void){ // build mask for wind direction
  uint8_t temp = PINC; // read Q1-Q6(PC0-PC5)
  temp &= B00111111; // clear bits 6 and 7
  temp |= (PIND & B11000000); // OR on Q7-Q8(PD6-PD7) bits
  return temp;
  DDRC &= B11000000; // PC0-PC5 = inputs (Wind Direction)
  PORTC |= B00111111; // switch on pull-up resistors
  DDRD &= B00001011; // PD4, PD5, PD6, PD7 = inputs (Wind Direction and Speed + 1-Wire) PD2 temporarily for RS485 disable
  PORTD |= B11110000; // switch on pull-up resistors
void loop(){
  int photocell = analogRead(ADC7);
  Serial.print(photocell, DEC);
  int voltmeter = analogRead(ADC6);
  Serial.print('\t');
  Serial.println(voltmeter, DEC);
  uint8_t d = make_wind(); // ;-)
  d = match_wind(WD, d);
  if (d < 16)
    Serial.println(windDirection[d]);
  else Serial.println("Invalid Direction");
robtillaart
Is it possible to read the strength of the hall sensors? (now I see only 0/1)
If so these could be used to interpolate between the values. The 16 wind directions are steps of 360/16 = 22.5, if interpolation is possible you may could get to 5 degrees accuracy
Rob Tillaart
retrolefty
Not likely. Hall effect sensors come in two varieties, those with a digital output and those with a analog output. Sounds like this weather station is using simple digital output hall sensors.
Lefty
EmilyJane
They are Allegro 3144 which is now obsolete and replaced by the A1104. Unfortunately, like Lefty points out, they are digital devices, so no interpolation will be possible. Just from watching the wind vane while I had it up on a pole, the direction oscillated quite a bit. I don't know that wind direction is stable enough to warrant 5 degree resolution. Not Texas wind anyway. :) We have a saying here, if you don't like the weather just wait 5 minutes.
That's an interesting idea though. If I ever decide to replace the circuit board, I could try linear Hall sensors.
Coding Badly
Nice!
A suggestion and an idea.  Suggestion...
const char* windDirection[17] = { // strings for the 16 wind directions
 "SW", "WSW", "W", "WNW", "NW", "NNW", "---"};
...very slightly simplifies displaying the wind...
uint8_t d = make_wind(); // Sophomore humor.  Got to love it.  Hmm, I think I'll watch Shaun the Sheep tonight...
Idea... interpolating (guessing) the wind direction... By tracking the wind direction versus time, it is possible for the application to provide a guess at the exact wind direction.
EmilyJane
I just finished modifying the board to include a 4K7 pull-up on the 1-wire pin. The DS1850 that I removed is obsolete too. The Chinese must have a stockpile of old parts. Or maybe they buy them up as they go obsolete.
I don't know if I'll put a temp sensor back inside the enclosure or not. It's useless for weather applications.
I removed 4 (of the 35!) LEDs just to give myself a little room to work. I may remove all of them. That will free up 6 I/O pins. Maybe I'll leave a couple as a warning to low flying birds or squirrels.  :)
EmilyJane
So, if i don't get a match, I display "---"? That's a good idea. I think it's physically impossible to not have one of those patterns though. That would signal a problem with the circuit.
That's an interesting idea. That would be helpful for displaying trends also. I'll work on that. I'll probably average wind speed over some period also.
Sometimes you get tired of meaningful function names and have to go with a little smile. :) Makes life a treat!
Coding Badly
Bah!  I grew up in the place that has the World's Record for the fastest temperature change.  Texas weather is slow and stable by comparison.   :D
EmilyJane
Sounds like Gunnison. I used to have a house in Crested Butte and one day in Almont they measured -60! You had to keep your car battery indoors.
robtillaart
Point of attention is if it alternates around 360 / 0 degrees,
The way I wouold approach it is count the number of times every individual sensor is triggered. There are 8 sensor so 8 counters, e.g. B00111111 means count[7]++ and count[6]++ . After a number of measurements a nice frequency diagram will come up from which the average can be derived.
Rob Tillaart
