Ok, it seems you need very specific advice.
You don't ever connect SDA directly to VDD, VDD, VCC, Vcc, +5V, + 3V, +3.3V, +1.8V +ve supply or Gnd,
How would you pull it down if you did?
To connect more than one device to SDA (and SCL of course) you make sure the devices don't have the same address, then you connect all the SDA (and SCL) lines together, and make sure that SDA is pulled up, and that SCL is also pulled up
And no, you can't use a single resistor to pull up both.
