Then it should work but you will probably get less than full power from the motor because you will want to restrict the current to it's design specification of around 10A.
What are you trying to do? A sensorless ESC is not going to usable at low speed at all.
Most ESC's startup sequences assume a propeller as the load, which has low inertia. The
open-loop part of the startup sequence for ESC designed for airscrews may not work with
a large heavy wheel at all.
Not sure what the specs of the motor are, but a sensored ESC will be necessary to
get closed loop control (and thus control and torque at low speed or stationary). I suspect
you will need closed loop control for your application, but you've not actually stated
definitely what you are trying to do...
You'll need to do the shopping, but if in doubt post the product link(s) here so we can
assess it.
