Topic: Inductive RPM sensing circuit (Read 357 times) previous topic - next topic
lodgernz
In this circuit, only the 1N4148 diode is named. Can anyone tell me what the other two diodes might be please?
Paul_KD7HB
I see only one other diode. Google will tell you about the BT149.
Paul
raschemmel
Quote
Or, if you knew schematic symbols, you would know it is an SCR.
Grumpy_Mike
Quote
No
In this circuit, only the two 1N4148 diodes are named. The other one can also be a 1N4148.
alesam
The other diode (placed in parallel with 3K3 resistor) most likely is a zener diode to limit a gate voltage.
Don't say "Thank you", just click on 'karma [add]' instead.
lodgernz
Wow! Thank you all for your contributions.
To summarise:
- I can assume that the naming of 1N4148 applies to both of the diodes in the vicinity of it;
- The diode across the 3k3 resistor can be also 1N4148, but would be better as a zener, even though it is not shown with the usual zener image;
- Confirming my basic knowledge that the BT149 is an SCR.
WattsThat
In the interest of completeness, the source of the schematic, something that the OP should have provided. The reason for the red asterisks explained.
https://www.sportdevices.com/rpm_readings.php
Vacuum tube guy in a solid state world
lodgernz
I'm sorry about that. I didn't understand the signifigance of the asterisks, and frankly, I still don't.
Grumpy_Mike
An asterisk against a component often means "read the notes associated with this diagram".
raschemmel
And then there's the asreisked asterisk which means "Read the Notes associated with the Notes
Associated with this diagram"...
Southpark
#10
Nov 27, 2020, 05:02 pm Last Edit: Nov 27, 2020, 05:05 pm by Southpark
True! There are three diodes there. And only 1 diode label. So assumptions need to be made. And then make sure we add a note to say that somebody forgot to label all the diodes 'properly'.
6v6gt
The asterisks are to indicate that the components are changes to the previous design.
