Topic: Error while upload Sketch to Arduino [ATmega328] (Read 313 times) previous topic - next topic
torstenluchs
My ATmega328 is connected via Mini UB cable to my windows 10 PC and I am using Arduino IDE.
I try to upload the simple Blink code to the Arduino, but I get the message below.
My local config is
Board "Arduino Nano"
Processor "ATmega328P (Old Bootloader)
Driver for CH340 is installed successfully.
and I am using a
Nano ATmega328 V3.1 Board with CH340 USB Chip
I already tried 3 different USB cables, but none of them worked.
Any ideas?
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
Beim Hochladen des Sketches ist ein Fehler aufgetreten
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xfc
         Hardware Version: 2
         Firmware Version: 0.16
         Vtarget         : 0.0 V
         Varef           : 198634860.8 V
         Oscillator      : Off
         SCK period      : 16390338.6 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0xfc
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
