Topic: expected initializer before 'int'. (Read 14274 times) previous topic - next topic
yazidabdulhamid
  Serial.begin(9600); //Set serial baud rate to 9600 bps
  pinMode (10,OUTPUT);
void loop ()
  int (valGas , valLDR) ;
    valGas = analogRead(0);
    valLDR = analogRead(1);
  Serial.println(valGas,DEC);
  Serial.print (",");
  Serial.println in(valLDR,DEC);
if(valGas<600) {
    digitalWrite (10,High);
  } else }
     digitalWrite (10,Low);
if (valLDR<400) {
   digitalWrite(11,High);
} else }
   digitalWrite(11,Low);
  delay (100) ;
i get error when i want to compile this code..can anybody help me to see what is wrong with my code?
mmcp42
Code: [Select]
void loop ()
  Serial.print (",");
if(valGas<600) {
  } else }
if (valLDR<400) {
} else }
  delay (100) ;
makes it easier to read
try
Code: [Select]
int valGas;
int valLDR;
or
Code: [Select]
int valGas , valLDR ;
no brackets!
there are only 10 types of people
them that understands binary
and them that doesn't
yazidabdulhamid
sorry, my bad.
i try both ways..but still error.
mmcp42
you also need
Code: [Select]
void loop
... your code
you left out the "{" and "}"
yazidabdulhamid
#4
Sep 07, 2011, 01:17 pm Last Edit: Sep 07, 2011, 01:23 pm by yazidabdulhamid Reason: 1
Code: [Select]
  Serial.println(valgas,DEC);
  Serial.print (",");
  Serial.println(valLDR,DEC);
is this part right?
yazidabdulhamid
Code: [Select]
if(valGas<600) {
  } else }
if (valLDR<400) {
} else }
  delay (100) ;
is this the right way to write if-else statement?
PaulS
Quote
is this part right?
If you want that extra carriage return/line feed in the middle, yes. Seems strange to me, though.
Quote
Sort of. The braces are not all facing the right way, and they are not all on separate lines where they belong (in my opinion).
Code: [Select]
if(valGas<600)
yazidabdulhamid
Code: [Select]
void loop ()
  int valgas , valLDR;
    valgas = analogRead(0);
  Serial.print (",");
  Serial.println (valLDR,DEC);
if(valGas<600)
if (valLDR<400)
  delay (100) ;
this is my current coding,
however, i still got error at this part
Code: [Select]
if(valGas<600)
if (valLDR<400)
  delay (100) ;
mmcp42
look at you code
you have { and } all over the place
you should have
Code: [Select]
  .. all of your code
  if (condition)
    .. true code
    ... false code
use indents to help you keep track
and check matching { and }
PaulS
The IDE has a menu, Tools. On that menu, there is an item, Auto Format. Do your self a favor. Use that tool. Often. It will fix all your random indents. It will also line up all your curly braces, indenting in and out as required. When it gets to the end of a function, and there are still closing } left over, they will bot be indented, leaving you a big clue that the number of open and close braces don't match.
ALL code needs to be inside a function. Not all of yours is. Why not?
