Dear all,
I am assembling some
Siguino boards with some schematic changes as attached (v1_sch.pdf).
First, I successfully used the
Nick Gammon loader in one of the boards (original Siguino schematic and PCB, removing the components not required on my project such as LDR and Hall Sensor) and using the Arduino UNO as ISP loader and Arduino IDE 1.8.13.
Then I moved to the second assembled PCB (like the schematic attached), and the load was not successful with
Atmega_Board_Programmer:
Atmega chip programmer.
Written by Nick Gammon
Version 1.38
Compiled on Dec 3 2020 at 18:16:51 with Arduino IDE 10813.
Attemping to enter ICSP programming mode .....................................................
Failed to enter programming mode. Double-check wiring!
Type 'C' when ready to continue with another chip
So I tried to use the Arduino ISP... After some comings and goings, I installed the
mod for ATMega328PB as suggested by
this topic, and it still not worked.
Then, I moved back to the first board (that was successfully bootloaded with
Nick Gammon loader), trying to identify if the problem was on second board's hardware or assembly (if ArduinoISP+mod works on the first board), but the first board stopped to work too.
Then I evidenced that I was using the wrong option for bootloading (Tools > Board: ATMega328PB External Clock), and did not change the Speed to 8MHz (used 16MHz as default), then the current output is:
Arduino: 1.8.13 (Windows 7), Board: "ATmega328PB External Clock, 16 MHz"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude.exe -CC:\Users\gubertoli\AppData\Local\Arduino15\packages\m328pb\hardware\avr\1.1.4/tools/avrdude.conf -v -patmega328pb -cstk500v1 -PCOM9 -b19200 -e -Ulock:w:0xFF:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD6:m -Ulfuse:w:0xE2:m
avrdude.exe: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\gubertoli\AppData\Local\Arduino15\packages\m328pb\hardware\avr\1.1.4/tools/avrdude.conf"
Using Port : COM9
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328PB
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude.exe: Device signature = 0xffffff (probably .reduced_core_tiny) (retrying)
Error while burning bootloader.
Reading | ################################################## | 100% 0.03s
avrdude.exe: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude.exe done. Thank you.
Then, I tried
Nick Gammon loader on the first board again, but it now outputs the same as the first code above
"Failed to enter programming mode. Double-check wiring!"So, I think that the issue is that both boards (ATMega328PB) are now in a misconfigured situation
I also tried
this topic's suggestion to change avrdude arguments in the command line to bring them back without success (used baud rates 4000, 9600)...
Can someone please help me put the microcontrollers back to the situation of being capable of loading bootloader?
Any feedback on the procedure to use Arduino ISP is also welcome.
