Topic: SPI Between 'Arduinos' (Read 7181 times) previous topic - next topic
WanaGo
Hello,
Never used SPI before between Arduino's before, have only used I2C.
Basically I have a atMega2560 talking over SPI to 3x atTiny84's.
Ignore the type of micros, I just am trying to get my head around the code to do what I want.
Basically, I want the 2560 to be the master, and to request data from each of the atTinys.
Each atTiny has a seperate Chip Select going to it from the Master.
Looking at the SPI library, http://arduino.cc/en/Reference/SPI , there doesnt seem to be much in there....
So basically after I set up who is master and who is slave, set the speed etc, is it just a case of doing the transfer() ?
I am searching more, but thought I would post incase someone knows how to do this. I am just wanting to set up a quick test program to prove the point. atTiny does stuff and then when requested from the 2560, it will give up a value. Job done.
Any help would be very handy.
Thanks
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
WanaGo
Thanks Nick
Code doesnt compile in the atTiny84 (I found another post of yours I stole some test code from).
I put the core for the atTiny84 that I found on the forum from CodingBadly, however I am not sure if SPI is supported yet or not.
Damn.
nickgammon
The AtTiny25/45/85 seems to support SPI. Not sure about the 84.
WanaGo
I get these errors
In file included from Brick_Tiny_Functions.cpp:1:
D:\Projects\Arduino-0022\libraries\SPI/SPI.h: In static member function 'static byte SPIClass::transfer(byte)':
D:\Projects\Arduino-0022\libraries\SPI/SPI.h:56: error: 'SPDR' was not declared in this scope
D:\Projects\Arduino-0022\libraries\SPI/SPI.h:57: error: 'SPSR' was not declared in this scope
D:\Projects\Arduino-0022\libraries\SPI/SPI.h:57: error: 'SPIF' was not declared in this scope
D:\Projects\Arduino-0022\libraries\SPI/SPI.h: In static member function 'static void SPIClass::attachInterrupt()':
D:\Projects\Arduino-0022\libraries\SPI/SPI.h:63: error: 'SPCR' was not declared in this scope
D:\Projects\Arduino-0022\libraries\SPI/SPI.h:63: error: 'SPIE' was not declared in this scope
D:\Projects\Arduino-0022\libraries\SPI/SPI.h: In static member function 'static void SPIClass::detachInterrupt()':
D:\Projects\Arduino-0022\libraries\SPI/SPI.h:67: error: 'SPCR' was not declared in this scope
D:\Projects\Arduino-0022\libraries\SPI/SPI.h:67: error: 'SPIE' was not declared in this scope
Brick_Tiny_Functions.cpp: In function 'void setup()':
Brick_Tiny_Functions:8: error: 'SPCR' was not declared in this scope
Brick_Tiny_Functions:8: error: 'SPE' was not declared in this scope
Brick_Tiny_Functions.cpp: In function 'void loop()':
Brick_Tiny_Functions:16: error: 'SPDR' was not declared in this scope
Brick_Tiny_Functions.cpp: In function 'byte slave()':
Brick_Tiny_Functions:22: error: 'SPSR' was not declared in this scope
Brick_Tiny_Functions:22: error: 'SPIF' was not declared in this scope
Brick_Tiny_Functions:23: error: 'SPDR' was not declared in this scope
nickgammon
Hmm. Looks like you might have to do a bit more work. I don't have an AtTiny84 to test on. Try reading this:
http://atmel.com/dyn/resources/prod_documents/doc2582.pdf
WanaGo
Success :)
Just some test code, here is the slave.
Code: [Select]
#include "pins_arduino.h"
byte Command;
 pinMode(MISO, OUTPUT);
 USICR = (1 << USIWM0) | (1 << USICS1);
 Command = slave();  //receive data from Master
 if(Command == 10)
   USIDR = 5;  //Generic reply of 5
   USISR = (1 << USIOIF);
   USIDR = 7;  //Generic reply of 7
byte slave()
 while (!(USISR & (1 << USIOIF)));
 return USIDR;
nickgammon
WanaGo
Ha - yeah.
Now I just need to fully understand why it is working and how to make it better!
These are going to be doing high speed counting so I need to make sure that what I have there isnt blocking, which I am thinking it might be with that while loop...
nickgammon
Yes it looks like it would block. Now you need to get an interrupt out of it. ;)
WanaGo
Your example you posted above in the link does interrupts does it... I havent looked again.
hmm
nickgammon
It mentions interrupts. I don't see any code there.
WanaGo
Care of GrayNomad - Thanks Rob!
Code: [Select]
byte Command;
   USICR = (1 << USIWM0) | (1 << USICS1) | (1 << USIOIE);
ISR (USI_OVF_vect)
  Command = USIDR;
  if(Command == 10)
nickgammon
Better would be:
Code: [Select]
ISR (USI_OVF_vect)
 Command = USIDR;
 if(Command == 10)
 USISR = 1 << USIOIF;
Otherwise you don't clear the interrupt bit if you don't match the "if". (Although in this case you would, of course).
Also make "byte Command;" volatile, otherwise move it into the ISR.
WanaGo
