Topic: Wifi Rev 2 not working without USB connection (Read 136 times) previous topic - next topic
Titanium69
This is a repost of posting #632544 (very old), but is exactly same issue I am running into now.
What Works:
I purchased 2 Arduino UNO WiFi Rev 2 units. The boards both work great when they are powered by the USB port.  I am able to upload sketches and run them with ALL functionality including WiFi connectivity.
PROBLEM:
However when I plug in any 9-12 volt supply and remove the USB connection, the UNO WiFi Rev 2 boards will not function.  A Network scan shows they aren't even connected to the network.  The green onboard power LED is on. Pressing the reset button does not change anything.
Anyone have any insight to this issue?
You laugh I laugh
You cry I cry
You fall off a bridge I laugh so hard I fall off with you
missdrew
What is the rating of the power supply you are keeping secret?
Titanium69
9V battery connected via the barrel connector
You laugh I laugh
You cry I cry
missdrew
That cannot deliver the current. That is why it is not working. THe PP3 can deliver around 250mA of power, your board uses 500mA - 1A when using WiFi
Titanium69
Yes, that's exactly what it was. Added a small switching supply (12V 3A) and it works.
Thanks.
You laugh I laugh
You cry I cry
