Topic: How to condition a VSS signal? (Read 499 times) previous topic - next topic
kitt3000
Hello,
First time posting to this forum. I'm working on a project to create a few digital gauges for a car. I'm using an Arduino Uno to capture the data and send it off to a python program. I'm struggling with the vehicle speed sensor (VSS). Currently I have the VSS plugged into the transmission, its an 8k ppm sensor powered by 12v the sensor generates a 5v ppm signal. I currently have it grounded to the vehicle's chassis, the 12v lead is going to a constant 12v source under the dash and the signal wire is running to the Arduino pin 5.
The issue im having is when I start the engine and the car is in park, I get erratic readings ranging from 4-8 mph, when I start to drive the car the readings increase as expected but when I come to a stop, it still is reading erratically between 4-8 mph.  I've tried conditioning the signal by adding a voltage divider using all sorts of resistors ranging from 100ohms up to 10k but still get the erratic readings. I'm not too seasoned when it comes to filtering signal.  I've blown up google trying to figure this out. There are a bunch of forums on this topic but very few dealing with real cars. Something is just not clicking with me.
Could someone give me an idea on what I can try next?
This is the type of voltage divider I tried using.  The signal is 5 volts instead of 12v for the signal
Voltage Divider and Zener Diode
Here is the VSS im using
https://www.ebay.com/itm/Universal-SPEEDOMETER-SENDER-GM-Mopar-VW-Sending-Unit-7-8-18-Thread-Brand-New/303110450853?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D54d257664b9547beb0c835ca72c2e012%26pid%3D100005%26rk%3D3%26rkt%3D12%26mehot%3Dpf%26sd%3D112961565082%26itm%3D303110450853%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851&fbclid=IwAR08-hFjDX489TruIVpHpktHgBQvJUEQCrf8B0XO2ASP64hBASHcBmt9G80
Below is my complete sketch. The speedometer portion I got from this post http://matthewcmcmillan.blogspot.com/2014/02/arduino-digital-speedometer.html
Code: [Select]
#include <SPI.h>
#include <Wire.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM303DLH_Mag.h>
Adafruit_LSM303DLH_Mag_Unified mag = Adafruit_LSM303DLH_Mag_Unified(12345);
const byte tachInterrupt = 1; // tach signal on interrupt 1 (digital pin 3)
byte engineCylinders = 8; // for tach calculation (pulses per revolution = 2 * cylinders / cycles)
byte engineCycles = 2; // for tach calculation
int refreshInterval = 500; // milliseconds between sensor updates
float speedMph = 0;
volatile int RPMpulses = 0;
static const int RXPin = 4, TXPin = 5;
static const uint32_t GPSBaud = 9600;
float declinationAngle = 0.17685997269;
//Fuel
int analogPin= 0;
int Vin= 5;
int raw = 0;
float Vout= 0;
float R1= 10;
int fuelLevel= 0;
float buffer= 0;
int prevFuelReading = 0;
int currentFuelLevel = 0;
bool firstFuelReading = true;
//vehicle speed sensor
const int hardwareCounterPin = 5;
const int samplePeriod = 500; //in milliseconds
const float pulsesPerMile = 8000; // this is pulses per mile for Toyota. Other cars are different.
const float convertMph = pulsesPerMile/3600;
volatile unsigned int count;
float mph;
volatile unsigned int imph;
int roundedMph;
int previousMph;
int prevCount;
volatile unsigned int currentSpeed;
volatile unsigned int filteredSpeed;
int speedo;
const long interval = 1000;
// The TinyGPS++ object
//TinyGPSPlus gps;
// The serial connection to the GPS device
//SoftwareSerial ss(RXPin, TXPin);
  pinMode(3, INPUT_PULLUP); // enable internal pullup for tach pin
  pinMode(5, INPUT_PULLUP);
  //attachInterrupt(tachInterrupt, countRPM, FALLING);
  //ss.begin(GPSBaud);
  //compass
  if (!mag.begin())
    /* There was a problem detecting the LSM303 ... check your connections */
    Serial.println("Ooops, no LSM303 detected ... Check your wiring!");
    while (1);
  TCCR1A = 0; //Configure hardware counter
  TCNT1 = 0;  // Reset hardware counter to zero
    bitSet(TCCR1B, CS12); // start counting pulses
    bitSet(TCCR1B, CS11); // Clock on rising edge
    delay(samplePeriod);
    TCCR1B = 0; // stop counting
    count = TCNT1; // Store the hardware counter in a variable
    mph = (count/convertMph)*10; // Convert pulse count into mph.
    imph = (unsigned int) mph; // Cast to integer. 10x allows retaining 10th of mph resolution.
    int x = imph / 10;
    int y = imph % 10;
    // Round to whole mile per hour
    if(y >= 5){
      roundedMph = x + 1;
    }else{
      roundedMph = x;
    //If mph is less than 1mph just show 0mph.
    //Readings of 0.9mph or lower are some what erratic and can
    //occasionally be triggered by electrical noise.
    if(x == 0){
      roundedMph = 0;
    // Don't display mph readings that are more than 50 mph higher than the
    // previous reading because it is probably a spurious reading.
    // Accelerating 50mph in one second is rocketship fast so it is probably
    // not real.
    if((roundedMph - previousMph) > 50){
      currentSpeed = previousMph;
    }else{
        currentSpeed = roundedMph;
    previousMph = roundedMph; // Set previousMph for use in next loop.
    //Serial.println(getRPM());
    int heading = compass();
    heading += declinationAngle;
    // Normalize to 0-360
    if (heading < 0)
      heading = 360 + heading;
    prevFuelReading = fuelLevel;
    raw= analogRead(analogPin);
    int raw= analogRead(analogPin);
    fuelLevel = map(raw, 0, 1024, 0, 300);
    if(fuelLevel - prevFuelReading  > 10 && firstFuelReading == false)
      currentFuelLevel = prevFuelReading;
      currentFuelLevel = fuelLevel;
      firstFuelReading = false;
    Serial.println(String(getRPM()) + "," + currentSpeed + "," + heading + "," + String(currentFuelLevel));
// counts tach pulses
void countRPM()
  RPMpulses++;
// checks accumulated tach signal pulses and calculates engine speed
// returns engine speed in RPM
// Resolution: 30000 * engineCycles / refreshInterval / engineCylinders RPM (for default values = 20 RPM)
int getRPM()
  int RPM = int(RPMpulses * (30000 / float(refreshInterval)) * engineCycles / engineCylinders / 2.0 ); // calculate RPM
  RPMpulses = 0; // reset pulse count to 0
  RPM = min(9999, RPM); // don't return value larger than 9999
  return RPM;
int compass() {
    sensors_event_t event;
    mag.getEvent(&event);
    float Pi = 3.14159;
    // Calculate the angle of the vector y,x
    float compassHeading = (atan2(event.magnetic.y, event.magnetic.x) * 180) / Pi;
    int heading = round(compassHeading);
    return heading;
  int getSpeed()
  // This uses the hardware pulse counter on the Arduino.
  // Currently it collects samples for one second.
DVDdoug
First, I'd try a "filter" capacitor across the 5K resistor.   100uf gives you an RC time constant of 1/2 second, which seems like a good starting point.
Then if you still have an "offset" you can subtract 8 (or 4 or whatever it "smooths-out" to).   Then re-adjust your calculation/mapping so everything else doesn't read 8 MPH slow.
That's a fairly standard straight-line calibration technique where you adjust the zero-point by adding or subtracting, and then you adjust the slope with an amplification factor to make the maximum or mid-point accurate.
kitt3000
@DVDdoug, thank you for the reply! I was thinking about using a capacitor like this one
https://www.futurlec.com/Capacitors/C100U25E.shtml
Would that work? Im really sorry for not understanding, but when you say use the capacitor across the 5k resistor, how would that connect? Could you provide a diagram on how to wire it in?
raschemmel
I am not a software person so I couldn't figure out where the code was specifically for reading the VSS.
I can see you are using analog input for other sensors but your schematic indicates you are using digital
input for the VSS. Can you please post JUST the VSS relevant code ?
What function are you using to read it ?
kitt3000
#4
Jan 16, 2021, 07:18 pm Last Edit: Jan 16, 2021, 07:38 pm by kitt3000
@raschemmel The below code is the portion that reads and converts the digital input pin 5 to mph
Code: [Select]
    int x = imph / 10;
    int y = imph % 10;
    if(y >= 5){
      roundedMph = x + 1;
    }else{
      roundedMph = x;
    if(x == 0){
      roundedMph = 0;
    // not real.
    }else{
raschemmel
I looked through your declarations:
Code: [Select]
const byte tachInterrupt = 1; // tach signal on interrupt 1 (digital pin 3)[color=#222222][/color]
byte engineCylinders = 8; // for tach calculation (pulses per revolution = 2 * cylinders / cycles)[color=#222222][/color]
byte engineCycles = 2; // for tach calculation[color=#222222][/color]
int refreshInterval = 500; // milliseconds between sensor updates[color=#222222][/color]
float speedMph = 0;[color=#222222][/color]
volatile int RPMpulses = 0;[color=#222222][/color]
static const int RXPin = 4, TXPin = 5;[color=#222222][/color]
static const uint32_t GPSBaud = 9600;[color=#222222][/color]
float declinationAngle = 0.17685997269;[color=#222222][/color]
//Fuel[color=#222222][/color]
int analogPin= 0;[color=#222222][/color]
int Vin= 5;[color=#222222][/color]
int raw = 0;[color=#222222][/color]
float Vout= 0;[color=#222222][/color]
float R1= 10;[color=#222222][/color]
int fuelLevel= 0;[color=#222222][/color]
float buffer= 0;[color=#222222][/color]
int prevFuelReading = 0;[color=#222222][/color]
int currentFuelLevel = 0;[color=#222222][/color]
bool firstFuelReading = true;[color=#222222][/color]
//vehicle speed sensor[color=#222222][/color]
const int hardwareCounterPin = 5;[color=#222222][/color]
const int samplePeriod = 500; //in milliseconds[color=#222222][/color]
const float pulsesPerMile = 8000; // this is pulses per mile for Toyota. Other cars are different.[color=#222222][/color]
const float convertMph = pulsesPerMile/3600;[color=#222222][/color]
volatile unsigned int count;[color=#222222][/color]
float mph;[color=#222222][/color]
volatile unsigned int imph;[color=#222222][/color]
int roundedMph;[color=#222222][/color]
int previousMph;[color=#222222][/color]
int prevCount;[color=#222222][/color]
volatile unsigned int currentSpeed;[color=#222222][/color]
volatile unsigned int filteredSpeed;[color=#222222][/color]
int speedo;[color=#222222][/color]
const long interval = 1000;[color=#222222][/color]
I am not very experienced with software but I can't tell where the actual sensor is in your code.
I don't see a comment saying "VSS SENSOR INPUT "
I also don't see any 'digitalRead' statements so it must be over my head.
My only question is , if it is a PPM signal like you say it is (as opposed to a PWM signal), why are you not using
pulseIn() ?
Shouldn't that be able to measure the pulse width ?
If that's a dumb question , it's ok to say so. I'm not ego-centric when it comes to learning new stuff. One of my
pet peeves is newbies posting dumb electronics questions without prefacing it with "I don't have a clue, is this
a valid question ?" They typically wait till they've tried running it before consulting instead of 'Hey, I wanna do
this, how should I go about it ?" You're way over my head with the software. I have no clue what you're doing.
but I do know what PPM is. Forgive me for asking but do you have an OSCILLOSCOPE to see what the signal
looks like so you can code accordingly ? Has it occurred to you (since you're so good with software, and
almost certainly do NOT have a scope or you would have included screenshots, ) to just put all that code you
posted on the shelf momentarily and just write a diagnostic routine to read the pulse and try to plot it ?
(if that's impossible feel free to say so)
kitt3000
To be honest, i really dont understand fully how the internal timer works for Arduino. From what i read, pin 5 is a part of the Timer1 monitoring, I took that code from an example that mirrored what i was trying to do. The person was using a VSS of his vehicle to measure the speed through the Arduino. He simply took the VSS raw signal and put it on pin 5.
My VSS says its a hall effect type generator. see the description in the link below:
I'm good with software but a real newb when it comes to circuitry. I tried just the pulseIn code example and I got nothing back.
If i use an Interrupt, it detects pulses as soon as i fire up the engine, so that wont work. I ordered a 100uf capacitor so i'll see if adding that helps.
TomGeorge
Did you get the code from
and just edit it to get the Vss code?
I see other bit and pieces in your code.
I would suggest you just write/edit the tacho code and get that going before adding anything else to your code.
This way you will make sure your problems are purely because of the Vss and its code.
Thanks.. Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
TomGeorge
Can you please post a circuit diagram of your project please?
Not a Fritzy picture.
Thanks... Tom... :)
raschemmel
There's nothing special about pin-5(AFAIK).
kitt3000
#10
Jan 17, 2021, 04:43 pm Last Edit: Jan 17, 2021, 04:44 pm by kitt3000
@TomGeorge, Yes, that's the code I'm using from that link! I'm sure it would work fine if I could figure out how to make the signal less sensitive. I ordered a few capacitors that should be arriving today. I'll add one and see what happens. I'll try adding it as a low pass filter.
I've already commented out the Tach code and nothing else except for the compass is connected to the Arduino. But I have also tried a sketch with just the VSS code and same issue is happening.  I've attached a diagram of my circuit currently:
In the diagram, those are 10K resistors, not 10.
TomGeorge
#11
Jan 17, 2021, 08:06 pm Last Edit: Jan 17, 2021, 08:13 pm by TomGeorge
Without the sensor near any object, what is the output voltage, gnd or 5V?
What is the signal when you move a metal object or mount it to the sensor wheel.
What changes do you get if you can slowly move the wheel?
What cable and how long between sensor and controller?
Is it shielded?
I would suggest you supply 12V and gnd from the controller end of the cable, not from odd locations that are different to the controller gnd and supply.
The controller is measuring the signal with respect to its own gnd, not the gnd at the sensor end, there could be all sorts of currents running through the vehicle chassis between the sensor gnd connection and the controller gnd connection.
Thanks.. Tom... :)
kitt3000
I know the VSS sensor is good because I took the sensor wire that goes to pin 5 of the Arduino and plugged it into a working digital speedo that a friend gave me. The speed displays correctly. So here's my setup, I have my car on jack stands so that the rear wheels are off the ground, that way I can pull it into gear and the tires will spin simulating the car moving. I checked my VSS signal using a digital speedometer that was laying around. Its shows zero when the car is in park, when I put it in drive it shows 8 mph and when I rev it, it is increases as expected.
So I'm sure the issue I'm having is with my circuit set up. That's the part I don't understand. The code for the Arduino has been tested for a car via the link I posted earlier and it works. If someone could post a diagram of the correct way I should filter the VSS signal, id appreciate it. I'm a newb when it comes to circuits.
raschemmel
I guess my point was that if you had a scope you could see what the signal looks like when you put it in gear
when it is connected to  a working digital speedo. It should read 0mph if the car is stationary but in gear.
Without the schematic of the digital speedo, I have no idea why it reads correctly. My only question is :
"Once the car is actually moving >10mph, does it read correctly with your arduino circuit or is there some
error all the time. ?"
kitt3000
So I did another test where I disconnected the pin 5 wire from the sensor, I then started the car and I got the same erratic reading from 4-8 mph and this is without the VSS signal connected to pin 5 :o . Pin 5 only has the disconnected wire plugged into it. If I removed the wire from pin 5 the reading goes to 0 mph. What the heck is going on? The wire in pin 5 is acting like an antenna...
Any ideas?
