Hi Everyone,
I am getting some strange results from trying to run a 12 segment led bar (KWLR1230CDUGB) with a TX74HC595 and 3 NPN2222 on the common cathodes.
I have the 595 being controlled by an arduino mini and using a voltmeter I can see all the pins rising to 4.7v in series that matches my sketch.
If I connect either of the cathode pairs directly to ground everything works as expected. As I switch the ground to each cathode pair the led segment is divided into 3 segments of LEDs 4 in each. I can turn on the green, then the red, and then both to make yellow.
When I add in a npn 2222 for a low side switch I get sporadic behavior and it looks like in some cases the expected LEDs light and then the other 2 segments are very dull. The 3 out pins on the arduino all turn on as expected when I set them to high and show 4.7v.
I made this on a bread board and it worked. Tore it down and soldered everything on a PCB and I am having major issues.
Can someone advise on test points to further dissect what is wrong? And can someone confirm this is the correct way to do this?
Thank you!
