P Channel Mosfets are not going obsolete. They are less common than N-channel because they require an extra layer of doping compared to an N-Channel. This is because silicon is intrinsically N material.
So they cost more, do not perform as well as N-Channel making them less attractive for most applications.
For a 4.3 amp load you need at least a 10A device. Not knowing your packaging constraints I would suggest you look at something like: IRF7420TRPBF
I found this at Digikey using their filtering capability (really great). I specified I needed:
- P-Channel
- Continuous drain current of 10A and above
- Active part (ie not obsolete)
Be careful you have a thermal path from the Mosfet to the ambient air.
You can reduce the thermal load if you use a more capable Mosfet like SIS407DN-T1-GE3
Very ImportantYou can only put 5V on the MosFet gate (because you only have 5v. A gate voltage of 5V will not result in a resistance as quoted at the top of the data sheet. You will have to go to the graphs.
Another question: Is your load powered by 5V? If not there are likely more options.
