Thanks, it's was too avoid pack with hundreds of useless tubes
If you don't have "useless" pieces of heat shrink tubing, then there will come a time when you will need them!!
Keep ALL your cutoffs too.
The adhesive type heatshrink usually has 4:1 or better shrinkage.
I use meters of it to repair and rebuild cable looms.
50/16 means its 50mm now and down to 16mm when you shrink it.
That is adhesive heatshrink.
Tom...
