Topic: Gasboard 7500b (Read 148 times) previous topic - next topic
gilshultz
I would assume it will work fairly well, but I have no experience with it. Be sure you get the connection information etc, none of that showed up with your link.
This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
MarkT
#2
Jan 23, 2021, 04:11 pm Last Edit: Jan 23, 2021, 04:28 pm by MarkT
Without a good datasheet you're going to have to characterize its performance yourself - is it worth it?
[ I'd be worried the temperature independence isn't very good, or the basic accuracy is less than
you hope for ]
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
hammy
#3
Jan 25, 2021, 08:19 pm Last Edit: Jan 25, 2021, 08:23 pm by hammy
This link discusses the principal , it might help to know what you are trying to do ?
The system infers the percentage of oxygen in a mixture from the speed of sound in the gas . It is basically measuring density and as such is highly temperature dependant , and affected by what you put through it ( humidity of air would affect it ?)
https://www.ti.com/lit/an/slaa976/slaa976.pdf?ts=1611602176514&ref_url=https%253A%252F%252Fduckduckgo.com%252F
