Topic: grove high temperature sensor (Read 127 times) previous topic - next topic
cristi33
Hello everyone,
I bought 4 grove high temperature sensors in order to measure 4 points of a face. I find a programme for my first sensor but i do not understand: How can i see the values of the 4 sensors at the same time ? In others words ,How can I programme my 3 others sensor with the same arduino uno?
Thanks you for reading.
missdrew
Depends on the sensor, and the code you have already. But I see neither, so I can't help.
michalpuk
You just need to use the same initializing sequnce for 3 other sensor and store the values of reading in arrays
Ron_Blain
This would go better if you provided data on the sensors you have and the code you are using? How do your sensors communicate with your micro-processor?  There is a section called how to use this forum, you may wish to read it.
Ron
