Did you also select the correct port and bootloader version ?
It doesn't show a port option on the M1 Macbook. For the bootloader do you mean the arduino agent? I wasn't given an option for that but I could see that the download had "arm" in it so I assume that was correct.
Thanks. So I figured out what the serial ports are.
On my m1 macbook, I can get the UNO to work only on the desktop client. It correctly shows the "usbmodem101" port, and doesn't work if we select the "bluetooth" port.
In the m1 macbook chrome arduino create client, it does not detect the UNO. This is at least progress for me as I don't have to switch back and forth between my old macbook air and this new M1 macbook.
I've hit another snag and I don't know if I should post the question here or in a new thread. I just bought the MKR1010 WiFi board and for this one it doesn't work on both my old macbook air and my new m1 macbook in both the browser and desktop client. It seems there's another rabbit hole of drivers to install and to try out. I've installed the board manager "Arduino SAMD" It would really be great to auto detect these boards and suggest what libraries and board packages to install. I ordered the Arduino Uno WiFi Microcontroller rev2 and hoping that one is compatible.
michaelvo:
Please provide a detailed description of what you mean by "doesn't work".
michaelvo:
As @ballscrewbob already explained, there is currently absolutely no support for the Apple M1. This is a completely new architecture and all the tools will need to be recompiled, thoroughly tested, and then released in order to support it. You'll need to use your old computer for Arduino for the near future.
