Topic: problème de compilation (Read 238 times) previous topic - next topic
lucas_hdx
Code: [Select]
#include "HID-Project.h"
//#define VOLUME
//#define KYBDLEDS
#define ZOOMBTNS
// Define Arduino pin numbers for buttons and LEDs
#define led 13
#ifdef VOLUME
#define ROTARY_A 5
#define ROTARY_B 6
#define ROTARY_C 7
#endif
#ifdef KYBDLEDS
#define CAPSLOCKLED 2
#define SCRLLOCKLED 3
#define NUMLOCKLED 4
#endif
#ifdef ZOOMBTNS
#define BTN1 8
#define BTN2 9
#define BTN3 10
#define BTN4 A0
#define BTN5 A1
#define BTN6 A2
#define NUMBUTTONS 6
int buttons[NUMBUTTONS] = {BTN1, BTN2, BTN3, BTN4, BTN5, BTN6};
unsigned long btntime[NUMBUTTONS];
boolean btnpress[NUMBUTTONS];
#endif
#ifdef VOLUME
boolean A, a, B, b, C, c;
#endif
char line[80];
unsigned long t;
int n;
//  Serial.begin(38400);
//  Serial.write("Starting...\n");
//  Serial.end();
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);
#ifdef VOLUME
  pinMode(ROTARY_A, INPUT_PULLUP);
  pinMode(ROTARY_B, INPUT_PULLUP);
  pinMode(ROTARY_C, INPUT_PULLUP);
#endif
#ifdef KYBDLEDS
  pinMode(CAPSLOCKLED, OUTPUT);
  pinMode(SCRLLOCKLED, OUTPUT);
  pinMode(NUMLOCKLED, OUTPUT);
  // Flash the LEDs just to show we're in business
  digitalWrite(CAPSLOCKLED, HIGH); delay(200);
  digitalWrite(SCRLLOCKLED, HIGH); delay(200);
  digitalWrite(NUMLOCKLED, HIGH); delay(200);
  digitalWrite(CAPSLOCKLED, LOW); delay(200);
  digitalWrite(SCRLLOCKLED, LOW); delay(200);
  digitalWrite(NUMLOCKLED, LOW); delay(200);
#else
  for (int i=0; i < 3; i++) {
  digitalWrite(led, HIGH); delay(20);
  digitalWrite(led, LOW); delay(200);
  digitalWrite(led, LOW); delay(500);
#endif
#ifdef ZOOMBTNS
  for (int i = 0; i < NUMBUTTONS; i++) {
    pinMode(buttons[i], INPUT_PULLUP);
    btntime[i] = 0;
    btnpress[i] = false;
#endif
#ifdef VOLUME
  a = b = c = false;
#endif
#ifdef KYBDLEDS
  t = 0;
  n = 0;
#endif
#if defined(KYBDLEDS) || defined(ZOOMBTNS)
  BootKeyboard.begin();
#endif
#ifdef VOLUME
  Consumer.begin();
#endif
//  System.begin(); // For System functions
//  Gamepad.begin(); // For gamepad functions
//  Mouse.begin(); // For mouse functions
//  AbsoluteMouse.begin(); // For the Absolute Mouse
  int leds;
#ifdef VOLUME
  A = digitalRead(ROTARY_A) == LOW;
  B = digitalRead(ROTARY_B) == LOW;
  C = digitalRead(ROTARY_C) == LOW;
  if (A && !a) {
    if (B) {
      n++; if (n > 100) n = 100;
      Consumer.write(MEDIA_VOL_UP);
    else {
      n--; if (n < 0) n = 0;
      Consumer.write(MEDIA_VOL_DOWN);
//      sprintf(line, "%d\n", n);
//      Serial.write(line);
  a = A;
  if (C && ! c) {
    Consumer.write(MEDIA_VOL_MUTE);
//      sprintf(line, "!\n");
  c = C;
#endif
#ifdef KYBDLEDS
  if (millis() > t + 10) {
    t = millis();
    leds = BootKeyboard.getLeds();
    if (leds & LED_CAPS_LOCK)
    if (leds & LED_SCROLL_LOCK)
    if (leds & LED_NUM_LOCK)
#endif
#ifdef ZOOMBTNS
    if (!digitalRead(buttons[i])) {
      // Button pressed (negative logic)
      if (btntime[i] == 0) {
        // Button has just been pressed
        btntime[i] = millis();
      else {
        // Button is still pressed
        if (millis() - btntime[i] > 20 && !btnpress[i]) {
          // This is not just a glitch
          btnpress[i] = true;
          // Now do your stuff!
          switch (i) {
#if 1
          case 0: // Alt-F2: Gallery view
            BootKeyboard.press(KEY_LEFT_ALT);
            BootKeyboard.write(KEY_F2);
            BootKeyboard.release(KEY_LEFT_ALT);
          case 1: // Alt-F1: Speaker view
            BootKeyboard.write(KEY_F1);
          case 2: // Alt-M: Mute all
            BootKeyboard.write(KEY_M);
          case 3: // Alt-A: Mute self
            BootKeyboard.write(KEY_A);
          case 4: // Alt-F: Full screen
            BootKeyboard.write(KEY_F);
          case 5: // Alt-S: Share screen
            BootKeyboard.write(KEY_S);
#else
          case 0:
            BootKeyboard.write(KEY_0);
          case 1:
            BootKeyboard.write(KEY_1);
          case 2:
            BootKeyboard.write(KEY_2);
          case 3:
            BootKeyboard.write(KEY_3);
          case 4:
            BootKeyboard.write(KEY_4);
          case 5:
            BootKeyboard.write(KEY_5);
#endif
    else {
      // Button not pressed
      if (btntime[i] != 0) {
        // Looks like it's just been released
        btntime[i] = 0;
#endif
Bonjour à tous,
j'aurais besoin de votre aide car je suis actuellement sur un projet assez complexe.
Ce projet est de réaliser un Stream Deck (boitier avec des raccourcis clavier) j'utilise donc un arduino pro micro.
Le problème que je rencontre est que lorsque je compile j'ai une erreur "SingleReport/SingleAbsoluteMouse.h"
Je suppose donc que c'est une erreur de bibliothèque. Mais quand je recherche sur intenet je ne trouve rien dutout
a part une bibliothèque SingleReport.h
Je l'ai donc essayé mais toujours la même erreur.
Si quelqu'un à déja eu ce problème ou si quelqu'un pourrais m'aider ce serait cool.
Merci d'avance et bonne soirée.
Code: [Select]
In file included from C:\lucas\StreamDeck pousser\sketch_jan23a\sketch_jan23a.ino:1:0:
HID-Project.h:39:10: fatal error: SingleReport/SingleAbsoluteMouse.h: No such file or directory
 #include "SingleReport/SingleAbsoluteMouse.h"
compilation terminated.
exit status 1
al1fch
#1
Jan 24, 2021, 10:12 pm Last Edit: Jan 24, 2021, 10:29 pm by al1fch
Bonsoir
C'est dans ton ordinateur qu'il faut chercher !!
La première ligne de "ton" programme appelle la librairie HID-project  , a-t-elle été correctement et complètement installée ?  (elle est installable par le gestionnaire de Librairies)
Référence ici :  https://github.com/NicoHood/HID
Elle contient plusieurs dossiers dont un dossier nommé SingleReport qui lui même contient le fichier SingleAbsoluteMouse.h et beaucoup d'autres....
lucas_hdx
effectivement c'était bien ca mais pour chaque bibliothèque il n'arrive pas à trouver son chemin tout seul. Le fichier est pourtant bien placé.
J'ai déja essayer avec les préférences mais sa ne change rien...
fdufnews
Tu l'as mise où ta librairie?
lucas_hdx
dans le même dossier que mon ficher arduino.ino
fdufnews
#5
Jan 25, 2021, 08:18 pm Last Edit: Jan 27, 2021, 10:55 am by fdufnews
Tu devrais regarder ça
lucas_hdx
Voilà installer etc mais nouvelle erreur
Code: [Select]
In file included from sketch\HID-Project.h:39:0,
                 from C:\lucas\StreamDeck pousser\sketch_jan23a\sketch_jan23b\sketch_jan23b.ino:5:
sketch\SingleReport/SingleAbsoluteMouse.h:29:26: fatal error: HID-Settings.h: No such file or directory
 #include "HID-Settings.h"
exit status 1
Erreur lors de la compilation.
Je suppose que c'est la bibliothèque "HID-Settings.h"
Mais elle est bien présente je l'ai même prise séparément avec le fichier mais rien ne fonctionne.
Quelqu'un à déja eu ce problème ?
Mon code de base
Code: [Select]
// Zoom Buttons
//#define VOLUME
//#define KYBDLEDS
#define ZOOMBTNS
#define led 13
#ifdef VOLUME
#define ROTARY_A 5
#define ROTARY_B 6
#define ROTARY_C 7
#endif
#ifdef KYBDLEDS
#endif
#ifdef ZOOMBTNS
#define BTN1 8
#define BTN2 9
#define BTN3 10
#define BTN4 A0
#define BTN5 A1
#define BTN6 A2
#endif
#ifdef VOLUME
#endif
char line[80];
unsigned long t;
int n;
//  Serial.end();
#ifdef VOLUME
#endif
#ifdef KYBDLEDS
#else
#endif
#ifdef ZOOMBTNS
    btntime[i] = 0;
#endif
#ifdef VOLUME
  a = b = c = false;
#endif
#ifdef KYBDLEDS
  t = 0;
  n = 0;
#endif
#endif
#ifdef VOLUME
  Consumer.begin();
#endif
  int leds;
#ifdef VOLUME
  if (A && !a) {
    if (B) {
    else {
  a = A;
  if (C && ! c) {
  c = C;
#endif
#ifdef KYBDLEDS
    t = millis();
#endif
#ifdef ZOOMBTNS
      else {
          btnpress[i] = true;
          switch (i) {
#if 1
#else
          case 0:
          case 1:
          case 2:
          case 3:
          case 4:
          case 5:
#endif
    else {
        btntime[i] = 0;
#endif
lesept
As-tu relancé l'IDE après avoir installé la bibliothèque?
A force d'essayer on finit par réussir... Donc, plus ça rate, plus on a de chances que ça marche (proverbe Sharduinok).
lucas_hdx
effectivement j'avais oublier de relancer mais maintenant j'ai une erreur qui me dit que la version ide n'est pas compatible (si j'a bien compris)
Code: [Select]
cc1.exe: error: -fno-fat-lto-objects are supported only with linker plugin.
exit status 1
lesept
lucas_hdx
lesept
OK, j'avais peur que ta carte ne soit pas compatible de la bibliothèque, mais ce n'est pas le cas.
Je n'ai jamais vu ce type d'erreur...
Essaye de désinstaller et réinstaller l'IDE, pas la dernière version mais la précédente.
lucas_hdx
quelle version est la meilleur ?
lesept
#13
Jan 27, 2021, 11:15 am Last Edit: Jan 27, 2021, 11:15 am by lesept
Je ne sais pas mais j'évite d'utiliser la dernière au cas où elle soit boguée.
lucas_hdx
voilà j'ai installer la version 1.8.0
mais nouvelle erreur qui fait un bon 200 lignes mais tout ne passe pas dans la case code ci dessous.
Code: [Select]
C:\lucas\StreamDeck\sketch_jan23a\libraries\HID-Project\src/MultiReport/../HID-APIs/NKROKeyboardAPI.hpp:79:8: error: redefinition of 'size_t NKROKeyboardAPI::removeAll()'
 size_t NKROKeyboardAPI::removeAll(void)
In file included from sketch\SingleReport/../HID-APIs/NKROKeyboardAPI.h:64:0,
                 from sketch\SingleReport/SingleNKROKeyboard.h:30,
                 from sketch\HID-Project.h:52,
                 from C:\lucas\ctrl volume\F6CJ9NZIY4Q9HRP\F6CJ9NZIY4Q9HRP.ino:5:
sketch\SingleReport/../HID-APIs/NKROKeyboardAPI.hpp:79:8: note: 'virtual size_t NKROKeyboardAPI::removeAll()' previously defined here
exit status 1
Erreur de compilation pour la carte SparkFun Pro Micro
