Topic: char-array (simple string) (Read 1 time) previous topic - next topic
_frank_
i build a char-array from serial-data...
now i want to disassemble this string.
Code: [Select]
    switch(int(input[0]))
      case 'D': //display DxyyText (x=row,yy=col)
          int row=int(input[1]);
          int col=int(input[2])*10+int(input[3]);
          char *text=&input[4];
          ShowTextOnDisplay(row,col,text);
it compiles, but is this the right way (moving the pointer to shorten the string)? how do i get the length of such an array?
documentation is a bit small about this
regards Frank
robtillaart
Better post the whole code to see how the input is filled etc
it looks quite right but you must be sure the array ends with a '\0' char, then you can use strlen().
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
_frank_
generation-code:
Code: [Select]
  char input[80];
  int incount = 0;
  if ( Serial.available())
    // read in a string byte by byte
    while (Serial.available())
      int current=Serial.read();
      if ((current != 13) && (current != 10) && (incount<79))
        input[incount++] = current;
      else break;
      delay(100);//give time to next byte passed to serial line
    input[incount] = '\0';  // puts an end on the string
do i have to include something to use strlen?
robtillaart
If the first Serial.available() fails (the one in the if ) then the array will not get filled at all.
(wait until data comes)
Code: [Select]
char input[80];
  int incount = 0;
  while (serial.available() <1 ); // forced wait until 1 char  Adapt number to your need if needed
  while (Serial.available() )
      int current = Serial.read();
      else break;
      delay(100);   // depends on how the other side sends ...
This forced wait does not garantee that the array is filled correctly but it captures at least 1 char (you may adapt that nr)
as incount does reflect the length of the array allready => strlen() is not needed
Rob Tillaart
_frank_
thanks for your suggestion...
my ShowTextOnDisplay-function...i want to change some chars to other bytecode...having problems with unicode (2 bytes). how can i solve this?
Code: [Select]
void ShowTextOnDisplay(int row,int col, char *text)
  lcd.setCursor(col,row);//second line, first col
  //now replacing wrong chars
  for (int i=0;i<strlen(text);i++)
    switch(int(text[i]))
      case '{': text[i]=0xFD; break;
      case '}': text[i]=0xFF; break;
      case '$': text[i]=0xA2; break;
PaulS
Code: [Select]
The switch statement requires a constant value as the argument. The text value is constant. Why are you casting it to an int?
Quote
That's pretty easy. Stop having problems.
On the other hand, if you explained what you are trying to accomplish, what is working, and what is not working, the answers you get would move further along the spectrum from smart ass to smart.
_frank_
the cast is practice from other languages ;), if you say its not needed, i can remove it :)
i want to control the µC-board from serial-line. sending commands like the display-command (beginning with D) should do something on the board. In this case show a Text on a specific position on the display. so i have to parse the string to get position (1 byte for line and 2 byte for column), after that the Text begins (modify pointer to avoid memcopy).
Some chars must changed because of different charsets of PC-OS/µC and Display...this is should be done in the function "ShowTextOnDisplay". The switch/case-structure only supports byte and some chars (e.g. german special chars) are encoded in unicode (2 byte)...maybe i have to use string-object to replace them (if it is to complicated to do with char-array).
What is the best way?
PaulS
Quote
Quote
So far, so good. That is what you are trying to accomplish.
Now, what is working and what is not working?
_frank_
Quote
do i have to use the string object or can this be done with char-array (replace unicode-char in special byte [display-charset])?
PaulS
Quote
No.
Quote
Yes.
_frank_
ok, how can i do this?
i assume (unicode=2 bytes) i cannot compare both bytes in the switch/case => check if first byte is a unicode entry char (imho 0xf*) and then check the next byte...coming to the main-problem...i cannot simple replace 2 bytes by 1 (have to move the string after unicode-char 1 byte to the beginning)
is it simpler to do it with string class?
regards Frank
PaulS
Quote
In the switch, no. But in the case for 0xF0 to 0xFF, you can deal with the nth character AND the (n+1)st character. Just move everything else up.
