Topic: ISR not in IRAM! (Read 190 times) previous topic - next topic
eddieari
Hallo,
wollte mir mal so eben eine Wetterstation bauen, Ausgangspunkt war folgende Anleitung https://tysonpower.de/blog/esp8266-weather-station
wie ihr seht, nutzt der Entwickler einen Wemos D1 mini. Ich hingegen nutze einen NodeMcu Lolin V3
So weit so gut.
Also da beide ESP8266 sind, dachte ich , dass der Code kompatibel sein sollte.
#include "DHT.h"
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
// Setup
#define WIFI_AP "XXX"                                         // AP SSID
#define WIFI_PASSWORD "XXXXX"                          // AP Password
char thingsboardServer[] = "192.68.176.2";                           // Thingsboard Server
#define TOKEN "THINGSBOARD TOKEN"                                                    // Thingsboard token
#define INTERVAL 30                                                 // Intervall of sending in seconds
// DHT
#define DHTPIN 2                                                    // DHT pin
#define DHTTYPE DHT22
//info config
const String device_model = "\"WEMOS D1 mini 2.3.0\"";
const String software_version = "\"ESP8266_Wetterstation_MQTT - 1.0\"";
//weather sensors
const byte windSpeedPin = 13;
const byte windDirPin = A0;
const byte rainPin = 12;
WiFiClient wifiClient;
// Initialize DHT sensor.
DHT dht(DHTPIN, DHTTYPE);
PubSubClient client(wifiClient);
int status = WL_IDLE_STATUS;
unsigned int windcnt = 0;
unsigned int raincnt = 0;
unsigned long lastSend;
//////////////// SETUP //////////////////////////////////////////////
  // pin for Wind speed
  pinMode(windSpeedPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(windSpeedPin), cntWindSpeed, RISING);
  pinMode(rainPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(rainPin), cntRain, RISING);
  pinMode(windDirPin, INPUT);
  dht.begin();
  delay(10);
  InitWiFi();
  client.setServer( thingsboardServer, 1883 );
  // send device attributes
  if ( !client.connected() ) {
    reconnect();
  // Prepare a JSON payload string
  String payload = "{";
  payload += "\"Device\":"; payload += device_model; payload += ",";
  payload += "\"Firmware\":"; payload += software_version; payload += ",";
  payload += "\"Sensors\":"; payload += "DHT22 - Wind Speed";
  payload += "}";
  // Send the payload
  char attributes[100];
  payload.toCharArray( attributes, 100 );
  Serial.println(payload);
  client.publish( "v1/devices/me/attributes", attributes );
  Serial.println("Send device attributes.");
  lastSend = millis() - INTERVAL*1000;
//////////////// LOOP //////////////////////////////////////////////
  // check connection
    reconnect();
  if ( millis() - lastSend > INTERVAL*1000 ) { // Update and send only after delay
    getAndSendTemperatureAndHumidityData();
  client.loop();        //keep connected, look for messages from server
//////////////// Functions //////////////////////////////////////////
 void getAndSendTemperatureAndHumidityData()
  Serial.println("Collecting Weather data.");
  // Reading temperature or humidity takes about 250 milliseconds!
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  //Calculate Wind Speed (klicks/interval * 2,4 kmh)
  float ws = (windcnt/INTERVAL) * 2.4;
  windcnt = 0;
  //Calculate Rain
  float r = (raincnt/2)*0.2794;
  raincnt = 0;
  // get wind direction
  float dirpin = analogRead(windDirPin)*(3.3 / 1023.0);
  String wd = "other";
  if(dirpin > 2.60 &&  dirpin < 2.70 ){
    wd = "N";
  if(dirpin > 1.60 &&  dirpin < 1.70 ){
    wd = "NE";
  if(dirpin > 0.30 &&  dirpin < 0.40 ){
    wd = "E";
  if(dirpin > 0.60 &&  dirpin < 0.70 ){
    wd = "SE";
  if(dirpin > 0.96 &&  dirpin < 1.06 ){
    wd = "S";
  if(dirpin > 2.10 &&  dirpin < 2.20 ){
    wd = "SW";
  if(dirpin > 3.15 &&  dirpin < 3.25 ){
    wd = "W";
  if(dirpin > 2.95 &&  dirpin < 3.05 ){
    wd = "NW";
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print("Windspeed: ");
  Serial.print(ws);
  Serial.print(" km/h ");
  Serial.print("Wind Direction: ");
  Serial.print(wd);
  Serial.print(" ");
  Serial.print("Rain: ");
  Serial.print(r);
  Serial.print(" mm ");
  String temperature = String(t);
  String humidity = String(h);
  String windspeed = String(ws);
  String winddir = String(wd);
  String rain = String(r);
  // Just debug messages
  Serial.print( "Sending Data : [" );
  Serial.print( temperature ); Serial.print( "," );
  Serial.print( humidity ); Serial.print( "," );
  Serial.print( windspeed ); Serial.print( "," );
  Serial.print( winddir ); Serial.print( "," );
  Serial.print( rain );
  Serial.print( "]   -> " );
  payload += "\"temperature\":"; payload += temperature; payload += ",";
  payload += "\"humidity\":"; payload += humidity; payload += ",";
  payload += "\"windspeed\":"; payload += windspeed; payload += ",";
  payload += "\"winddirection\":"; payload += winddir; payload += ",";
  payload += "\"rain\":"; payload += rain;
  payload += "}";
  // Send payload
  client.publish( "v1/devices/me/telemetry", attributes );
  Serial.println( attributes );
  lastSend = millis();
void InitWiFi()
  Serial.println("Connecting to AP ...");
  // attempt to connect to WiFi network
  WiFi.begin(WIFI_AP, WIFI_PASSWORD);
  WiFi.mode(WIFI_STA);
    Serial.print(".");
  Serial.println("Connected to AP");
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    status = WiFi.status();
    if ( status != WL_CONNECTED) {
        Serial.print(".");
    Serial.print("Connecting to ThingsBoard node ...");
    // Attempt to connect (clientId, username, password)
    if ( client.connect("ESP8266 Device", TOKEN, NULL) ) {
      Serial.println( "[DONE]" );
      Serial.print( "[FAILED] [ rc = " );
      Serial.print( client.state() );
      Serial.println( " : retrying in 5 seconds]" );
      // Wait 5 seconds before retrying
      delay( 5000 );
// Interupts
void cntWindSpeed() {
  windcnt++;
void cntRain() {
  raincnt++;
Allerdings hat mich nach den flashen im seriellen Monitor folgendes in dauerschleife erwartet:
0000 3ffee688 40204a5f
3fffffb0:  feefeffe feefeffe 3ffe84f0 40100f6d
<<<stack<<<
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ISR not in IRAM!
User exception (panic/abort/assert)
Abort called
>>>stack>>>
Nun weiß ich leider nicht mehr weiter und hoffe auf einen Hinweis.
Gruß
Thomas
combie
#1
Feb 22, 2021, 01:00 am Last Edit: Feb 22, 2021, 01:10 am by combie
Vielleicht mal die Doku lesen?!
 8)  8)  8)
Säge kein Sägemehl.
eddieari
#2
Feb 23, 2021, 09:32 am Last Edit: Feb 23, 2021, 09:44 am by eddieari
Vielen Dank für den Hinweis auf die Doku. Leider hatte ich die schon gelesen und muss sagen, dass  dies mich nicht wirklich weiter bringt.
Was für mich klar ist und ich mir zusammengereimt habe, ist:
vor die Funktion
sollte
ICACHE_RAM_ATTR
eingefügt werden.
Dies habe ich getan, was zu keiner Lösung geführt hat.
Daher bin ich offen für Vorschläge die über den Verweis auf die Doku hinaus gehen.
Gruß
Thomas
MicroBahner
#3
Feb 23, 2021, 09:49 am Last Edit: Feb 23, 2021, 09:51 am by MicroBahner
Ich sehe jetzt erstmal nicht, was die Funtion getAndSendTemperatureAndHumidityData() mit Interrupts zu tun hat. Die Interruptfunktionen sind andere:
Gruß, Franz-Peter
eddieari
Hallo Frank-Peter,
danke für die Antwort! Sehe ich ein, dass dort die Funktionen nicht vorhanden sind.
Hast du eine Idee, warum der Fehler auftritt.
Die Funktion
ist aus meiner Sicht richtig.
combie
#5
Feb 23, 2021, 10:47 am Last Edit: Feb 23, 2021, 11:54 am by combie
Warum fällt der Groschen nicht?
Übrigens, meine zweiter Name ist "DokuVorLeseVerweigerer".
Damit wirst du sie (die Doku) selber noch ein paarmal selber lesen müssen!
... bis er fällt, der Groschen ...
Säge kein Sägemehl.
eddieari
Frage an den "DokuVorlesungsVerweigerer"!
Wieviele von deine über 13000 posts beziehen sich auf "lese die Doku"!
Und wenn du ehrlich zu dir selbst bist! Wie beantwortest du die Frage, warum bin ich in diesem Forum? Helfen oder Nerven?
Sorry an alle anderen.
Dies geht natürlich nicht an euch!
Tommy56
Die meisten seiner Posts sind fachlich fundierte Inhalte.
Lies Dir doch noch mal die Antworten durch, die Du bekommen hast. Da wurde Dir auch schon mitgeteilst, was Deine ISR sind. Jedenfalls nicht das, was Du dafür hälst.
Gruß Tommy
"Wer den schnellen Erfolg sucht, sollte nicht programmieren, sondern Holz hacken." (Quelle unbekannt)
MicroBahner
#8
Feb 23, 2021, 01:12 pm Last Edit: Feb 23, 2021, 01:13 pm by MicroBahner
Die Funktion
Ich habe auch nicht geschrieben, dass diese Anweisungen falsch sind. Aber an diesen Anweisungen erkennst Du, was deine ISRs sind. Ich habe sie noch extra markiert. Und diese Funktionen benötigen das Attribut ICACHE_RAM_ATTR.
Gruß, Franz-Peter
Rentner
Hallo,
link zum lesen hast Du schon bekommen, aber sicher nicht richtig verstanden.
ich würde das so verstehen
// Interupts
ICACHE_RAM_ATTR void cntWindSpeed() {
  windcnt++;
Heinz
combie
Gerne doch!
Keine Statistik gemacht, bisher...
Denke schon, dass sich in ca 10% meiner Beiträge, Links zu maßgeblicher Information befinden
Hinzeigen ist einfach für mich.
Lesen, verstehen und anwenden, ist die Sache des Gegenübers.
Hier also deine.
Das ist einfach zu beantworten!
Ich bin in erster Linie hier um zu lernen.
Das Forum bietet mir "Probleme" und Anregungen, auf die ich aus eigener Kraft nie gekommen wäre.
Meine Dankbarkeit, dafür, möchte ich dadurch zeigen, dass ich dem ein oder anderen auf Pferd helfe.
Natürlich klappt das nicht immer, siehe dazu, wir beide.
Und sowieso halte ich Kommunikation für ein ganz spannendes Thema.
Da bin ich gerne bei, auch in Sachen Eskalation.
Helfen oder Nerven?
Hier könnte es evtl. sein, dass du ein Problem mit deiner Erwartungshaltung hast.
Oder, ich mit meiner.
Verflucht nochmal!
Den Link zur Doku, den ich dir habe zukommen lassen....
Ich erwarte, dass du sie liest.
Da steht im ersten Absatz ganz klar drin, was du zu tun hast.
Jetzt ist es an dir, das zu tun.
Lesen, verstehen und umsetzen.
Alternativ könntest du noch ein Weilchen erbost sein, und mit den Füßen auf dem Boden rumstampfen.
Auch die Schuld bei mir suchen.
Aber helfen, wird dir das nicht.
Säge kein Sägemehl.
eddieari
Danke Renter für deine hilfreiche Antwort.
Hatte mich da verrannt, denn ich hatte hinter ICACHE_RAM_ATTR void gesetzt hatte, damit hat es natürlich nicht funktioniert.
Manchmal ist ein kleiner Hinweis von extern Gold wert.
Danke
