Hi and hello
Information about Arduino board and the shield.:
Board: Arduino UNO R3 (without WIFI function)
Shield: Braccio Shield V4
The Uno alone with different code works fine, although when I stick it together with the shield. But when it'S togehter it is not possible to reprogramm it. Maybe something with the serial port, but I didn't understand that really.
The error message:
Code: [Select]
Arduino: 1.8.12 (Linux), Board: "Arduino Uno"
Der Sketch verwendet 4612 Bytes (14%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 418 Bytes (20%) des dynamischen Speichers, 1630 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
I tested it with to different UNOs and two different Computers. Always the same.
The Uno and the braccio is sold as a bundle:
Couldn'T believe that there is no work around or solution.
Best regards
p.s.: Requested also in Robo Section of the forum but thats not that frequented.
