Topic: Arduino Libraries Census and Repository (Read 20848 times) previous topic - next topic
PepeChorva
Hello Massimo,
Do you open the census to everybody? I think that would be good to know which libraries are in the census for avoiding to repeat them.
Another thing, I think the repository must have 2 parts, one for arduino 1.0 and another for before versions.
It's only a suggestion  ;)
Saludos,
José Chorva
www.pepechorva.com
@pepechorva on twitter
mrTee
Having something like the XBMC's adddon system sounds like a good plan, but wouldn't a package manager be a more logical choice? A package manager would, for example, make it much easier to handle dependencies between packages. There are many package managers to choose from, but I personally think that the cross-platform, open source package manager Zero Install would be perfect for this. One of the nice things of 0install is that packages can be managed both centralized and decentralized.
Targettio
I wasn't aware there were such things readily avaliable; I assumed the arduino team would need to start from scratch, which is why I used XBMC as a model. But if someone else has done the leg work for you then that seems like a easiler, quicker and better solution.
spicajames
pert
Is this still the way to publish libraries in https://github.com/arduino-libraries ??
No, I don't think that idea was ever fully implemented. The modern equivalent is to submit your library to Library Manager. For more information see: https://github.com/arduino/Arduino/wiki/Library-Manager-FAQ
