Topic: Need source for 3mm RGB LEDs (Read 9554 times) previous topic - next topic
SimbaSpirit
I can't seem to find a single source online for 3mm RGB LEDs that dont have a flash or fade gimmick. I just want an LED that'll turn on when I power it.
Has to be 3mm, 5mm is too big.
Anybody have a source??
macegr
Chiming in to agree. Pin spacing on 5mm RGB LEDs is already pretty close. You'll need to find a small RGB SMD LED...and all the ones I've found have been pretty expensive.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
CrossRoads
Would this be small enough?
http://www.superbrightleds.com/moreinfo/component-leds/rgb-5050-smd-led-120-degree-viewing-angle/322/1254/
http://www.superbrightleds.com/pdfs/5050-RGB.pdf
SimbaSpirit
Those SMDs are 5mm across.
I'm having someone cast resin for me, and need to get an RGB led in it.
The person is saying 5mm is too big to fit into the resin cast, so I'm stuck trying to find an RGB LED with dimensions less than 5mm.
CrossRoads
This is the smallest multicolor I've seen
http://www.superbrightleds.com/pdfs/XLampXP-E.pdf
Try checking
www.cree.com
directly and see what else they have.
SimbaSpirit
Yep nothing quite fits the bill.
I guess I'm going to butt heads with this guy until he sees things my way xD
1" diameter of resin... I can't imagine why a 5mm tip would be such a huge request lmao...
Thanks guys, glad I wasn't just crazy for not finding one!
CrossRoads
That seems odd - why require such a little LED with such a relatively big block?
1" = 2.54cm = 25.4mm , yes?
Good luck in your negotiations 8)
cmagagna
Here's 1.6mm^2 SMD ones, maybe they will work:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=754-1500-1-ND
Good luck!
