Topic: Global Server (Read 71 times) previous topic - next topic
ba_ber
Hi every one,
I'm new in arduino world and this is my first project.
The objectif is check from a web page if a vehicle is in the garage or not.
The sensor part of my code is okk and I can see the statue on a local server but i need hep to do the same on a global server.
/*Test version
 *Objectif:
 * If input return a certain value
 * send to server that the ambulance is here
 * else send to the server that the ambulance is away
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
//enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                 // your network key index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
   pinMode(A0, INPUT);
  // initialize digital pin LED_BUILTIN as an output
  pinMode(LED_BUILTIN, OUTPUT);
  // initialize serial communication at 9600 bits per second:
// check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to Network named: ");
    Serial.println(ssid);                   // print the network name (SSID);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();                           // start the web server on port 80
  printWifiStatus();                        // you're connected now, so print out the status
 int sensorValue = analogRead(A0); // read the input on analog pin 0
 delay(1000); // delay in between reads for stability (ou faut il mettre le delay?)
  // print out the value you read:
  Serial.println(sensorValue);
if (sensorValue >= 150)
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("new client");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println();
            client.print("est ce que l'ambulance est là?");
            // the content of the HTTP response follows the header:
            client.print("oui");
            client.print("non");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
            break;
          } else {    // if you got a newline, then clear currentLine:
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
thank's a lot if somebody can help me
(and sorry for my bad english I'm from switzerland)
