Topic: One-line algorithmic music (Read 17337 times) previous topic - next topic
stimmer
#15
Sep 27, 2012, 04:41 pm Last Edit: Sep 27, 2012, 04:57 pm by stimmer Reason: 1
DuaneB: Linking back here is fine, I don't have a website (yet).  I just had a go at building your version using an RGB LED, it looks cool 8) Try wiring up one of the tune select inputs to an LED output - it usually sounds terrible but sometimes you get funky mashups of two of the tunes  :smiley-mr-green: (All the tunes are working, although tune 4 needs you to press reset to get it to start.)
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
DuaneB
   I saw that I had my buttons connected out of order so yes, your right they do all work.
   As for pressing reset, I should really add a reset of the counter when ever the tune number changes.
   I will update my blog post and comments over the weekend, I will also add support for Leonardo's the timer output is connected to a different pin than it is on UNOs.
   The blog post is here -
http://rcarduino.blogspot.com/2012/09/algorithmic-music-on-arduino.html
Duane B.
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
DuaneB
Read this
then watch this
