Topic: Using Arduino Target (Read 847 times) previous topic - next topic
shas146
Hi Guys,
I have to use simulink and arduino for a PIL project. I am a noob just beginning to use both packages. Please help, I need to get on with the project and sumbit in 3 days :(
I downloaded the simulink support for arduino called Arduino Target. Then I followed the instructions in the readme file.
cd c:\ARDUINO_TARGET
addpath(fullfile(pwd,'arduino'),fullfile(pwd,'blocks'),fullfile(pwd,'demos'))
savepath
sl_refresh_customizations
arduino.Prefs.setArduinoPath('c:\Program Files\arduino\arduino-0018')
The following error appears at the last command line :
>> arduino.Prefs.setArduinoPath('C:\arduino-0022')
??? Error: File: Prefs.m Line: 97 Column: 23
Expression or statement is incorrect--possibly unbalanced (, {, or [.
I tried to look up Prefs.m but couldn't understand the code.
You can find Prefs.m here
http://www.mathworks.in/matlabcentral/fileexchange/30277-simulink-support-package-for-arduino/content/arduino/+arduino/Prefs.m
The problem seems is in the following line of the package:
function ports = searchForComPort(regCmdOutput)
            ports='';
            if nargin < 1
                if ispc
                    regCmd=['reg query '...
                            'HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\SERIALCOMM'];
                    [~,regCmdOutput]=system(regCmd);               <===========This line has problem
                end
            end
