Topic: I keep getting ÿ on my Serial Terminal? (Read 7468 times) previous topic - next topic
danpe
Oct 06, 2011, 01:42 pm Last Edit: Oct 06, 2011, 03:15 pm by Danpe Reason: 1
Hey,
I keep getting ÿ on the Serial Terminal, here is my build:
Arduino Duemlinove + Sparkfun WiFly Shield.
I'm communication with the WiFly using a C# .NET based application on my PC that connectes to the WiFly shield using AdHoc connection, opening Socket and start transmitting using TCP
Code: [Select]
this.Soc = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
The arduino has this loop:
Code: [Select]
       Serial.println("Initializing...");
       SpiSerial.begin();
       Serial.println("Ready.");
   while(SpiSerial.available() > 0) {
     byte b = SpiSerial.read();
     char c = char(b);
     Serial.print(c);
When i print the char i get ÿ...
Any ideas why this heppends ?
SurferTim
That is how a terminal displays 255 (-1).
danpe
So i just solved it with
Code: [Select]
if(c != (char)-1) but still, any idea why this heppends ?
SurferTim
It seems that the available() function is not working correctly. That is the response I get from client.read() if client.available() returns 0. That is the read() function returning "no characters available".
robtillaart
What is the signature of SpiSerial ?   does SPiSerial.Available returns a byte or an int ?
Have a link to the library?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
