Topic: LED Effects Recommendations (Read 4897 times) previous topic - next topic
ckeyes
Hey,
Complete noobie here but really want to get started with the Arduino. Need to program a 10m strip of LED's and was hoping I could get
some direction on the best hardware to get started with. I'm looking at either a HL1606 or LPD8808 strip, whichever you think has the best
possible effects, and an Arduino with power supply for them.
Any advice greatly appreciated!
Thanks,
Carl
Grumpy_Mike
As far as I can tell the HL1606 will allow you to control what the light does with an arduino where as the LPD8808 just cycles through it's own effects, so I would say a HL1606.
ckeyes
Doh. Typo...meant the LPD8806 lights.
marklar
The LPD8806 (now that you fixed the typo) is way better than the very bad HL1606 chip.  You for sure want the LPD8806 version.
http://www.adafruit.com/products/306
- Note is say individual control - 32 steps.  You don't get that with the HL1606 chip - in fact you don't get much with the HL1606 chip - hence the reason for the upgrade on that site :)
ckeyes
Thanks a bunch. Could you recommend the best Arduino to control a 10m strip?
Carl
Grumpy_Mike
With regard to control they are all very much the same so go with a Uno.
ckeyes
Thanks, got an UNO on order. Any help in locating effects code for the LPD8806's?
Not finding much yet.
Carl
ckeyes
#8
Oct 13, 2011, 04:34 pm Last Edit: Oct 13, 2011, 08:31 pm by ckeyes Reason: 1
Excellent, thanks. Is it possible to start/execute Arduino sketches using AppleScript?
My application requires that a remote machine send the machine the Arduino is connected
to, an AppleScript to execute various sketches.
Any info on controlling the Arduino with AppleScript greatly appreciated!
Thanks,
Carl
funkyguy4000
Accelerate to 88 miles per hour.
Grumpy_Mike
AppleScript is a scripting language to control Apple applications, you can not control an arduino directly from it. The arduino IDE has no support for AppleScript.
You have to go through an intermediate application that can then trigger a message to be sent over the serial port.
However I don't know of any. For this it would be better to start another thread in the Programming or Interfacing section, but please not both only one new thread.
ckeyes
brucethehoon
I can say that any chip controlled by the fastspi library is an easily controlled chip.
http://code.google.com/p/fastspi/
I use it with my custom ws2801 based light bars and find it a joy to work with (once you source the ws2801's themselves)
ckeyes
Might you have an opinion which LED strip chip set is the best for complex effects with an Arduino? The type of effects I'd like to achieve I haven't seen in any demo yet, as having a comet effect travel to LED 125, of a strip of 320, and stop there and begin shimmering out in both directions.
Probably a steep learning curve for a newbie like me but it would be good to know what is possible before I dive in with possibly a strip that can't be completely controlled
for most any effect. The LPD8806 seems promising if I knew it was capable of the type of effect above.
Many thanks!
Carl
ckeyes
Would love to hear from anyone on just how programmable the LPD8806 strips are...for example
if I could program things like I mentioned above.
Carl
