Topic: FM62429 Digital Volume? (Read 11980 times) previous topic - next topic
WilliamK Govinda
Guys, I found this cheap Digital Volume chip: FM62429 - its great, but the datasheet tells me its a 2-wire interface: Data, Clock - but doesn't show me what is transmitted. Can someone give me a hint, please?   :smiley-red:
http://www.fmsh.com/english/products/FM62429_ds_eng.pdf
Thank you, Wk
robtillaart
first idea: from datasheet - Gain is from 0- -83dB in 1dB steps so I think one byte should be sufficient.
google gave me zillion links to the same datasheet or rubbish,
seems you have to reverse engineer the spec.  clock in bytes and measure ....
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
WilliamK Govinda
Indeed. As soon as the chips arrive I will start playing around with it and see what happens, txs.
Wk
WilliamK Govinda
A great friend just pointed me this out:
Quote
the FM62429 is a "copy" of Mistubishi's M62429/FP
And he sent me all PDF data, here's some links:
http://william-k.com/temp/M62429P.pdf
8)
christianlykke
Do you mind sharing the part of your code where you are communicating with the volume control circuit?
I am having trouble sending 11 bits. How do you do that?
sonnyyu
Additional from FM62429, CSC62429, CD62429 is replacement for M62429 as well.
if I were you , I will send 11 bits as 2 bytes since Arduino is 8 bits cpu. first byte is first 8 bits data, second byte will be rest 3 bits plus "00000" as tail by using Arduino virtual serial/serial port. I do not have above IC. You could give it a try.
vile
Hello all,
if someone is interested, I'm running the M62429 on such a "Digital Stereo Audio Volume Control Board PT2259":  http://www.ebay.de/itm/Digital-Stereo-Audio-Volume-Control-Board-PT2259-Headphone-Audio-Amplifier-DIY-/141084601932?pt=DE_Computer_Sonstige&hash=item20d94c2e4c
If you do not use the rotary encoder but instead plug +5V, GND, DATA, and CLOCK to your Arduino it will work perfectly. The external power supply is also not needed.
I found a library and examples at this site https://github.com/krupski/M62429, but in the library the delay functions have wrong syntax, so change _delay_ms to delay and _delay_us to delayMicroseconds.
The following code is based on the library, but mine doesn't need a library, it's all in the code.
Code: [Select]
A little example sketch based on this lib: https://github.com/krupski/M62429/blob/master/M62429.cpp
int x=0;
int VolumePinDAT=7; // connect to DATA
int VolumePinCLK=6; // connect to CLOCK
void setup (void)
 pinMode(VolumePinDAT, OUTPUT);
 pinMode(VolumePinCLK, OUTPUT);
void loop (void)
 // sweep from quiet to loud
 for (x=0;x<=100;x++)
 setVolume(x);
 delay(100);
 // sweep back
 for (x=100;x>=0;x--)
 setVolume(x);
 delay(100);
// this function does the job
void setVolume (uint8_t volume)
uint8_t bits;
uint16_t data = 0; // control word is built by OR-ing in the bits
// convert attenuation to volume
volume = (volume > 100) ? 0 : (((volume * 83) / -100) + 83); // remember 0 is full volume!
       // generate 10 bits of data
data |= (0 << 0); // D0 (channel select: 0=ch1, 1=ch2)
data |= (0 << 1); // D1 (individual/both select: 0=both, 1=individual)
data |= ((21 - (volume / 4)) << 2); // D2...D6 (ATT1: coarse attenuator: 0,-4dB,-8dB, etc.. steps of 4dB)
data |= ((3 - (volume % 4)) << 7); // D7...D8 (ATT2: fine attenuator: 0...-1dB... steps of 1dB)
data |= (0b11 << 9); // D9...D10 // D9 & D10 must both be 1
for (bits = 0; bits < 11; bits++) { // send out 11 control bits
delayMicroseconds (2); // pg.4 - M62429P/FP datasheet
digitalWrite (VolumePinDAT, 0);
digitalWrite (VolumePinCLK, 0);
digitalWrite (VolumePinDAT, (data >> bits) & 0x01);
digitalWrite (VolumePinCLK, 1);
digitalWrite (VolumePinDAT, 1); // final clock latches data in
//return data; // return bit pattern in case you want it :)
Frederic_Plante
#8
Jul 26, 2014, 12:00 am Last Edit: Jul 26, 2014, 12:02 am by Frédéric_Plante Reason: 1
Ok, so final confirmation before I buy.
1.These chips FM62429 work well with Audio
2.Although they are not I2C they work with 2 Wires.
3.You are satisfy with the audio results
One more question, can you read the data that you send after you send? I mean if I set the volume value, can I go later and check what the value is set to? Or is the register write only?
As we fight our way northward into the great unknown, only that one thing remains certain...
jerome187
can this chip be used as an actual pot?
jerome187
anyone?  its advertised as a digital potentiometer  in many places
