Topic: Motor Unipolar ST28. What's wrong ? (Read 4197 times) previous topic - next topic
miniduino
Hi.
I'm triing to mount a motor unipolar ST28 mingjong 12Vc 320mA with this conection :
And datasheet secuence to turn motor. But it don't turn. Someone knows what it's wrong ?
I'm triing this code too as a similiar conection motor too but motor don't move.
Code: [Select]
const int ledPin = 13;
const int motorPin1 = 8;   // Pin Orange
const int motorPin2 = 9;   // Pin Yellow
const int motorPin3 = 10;  // Pin Pink
const int motorPin4 = 11;  // Pin Blue
int delayTime = 500; // Delay que determina la velocidad de giro
  pinMode(ledPin, OUTPUT);
  // ConfiguraciĆ³n de los PIN-es como salida digital
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorPin3, OUTPUT);
  pinMode(motorPin4, OUTPUT);
  // Los pongo todos a Cero
  digitalWrite(motorPin1, HIGH);
  digitalWrite(motorPin2, HIGH);
  digitalWrite(motorPin3, HIGH);
  digitalWrite(motorPin4, HIGH);
  delay(delayTime);
  digitalWrite(motorPin1, LOW);
  digitalWrite(motorPin2, LOW);
  digitalWrite(motorPin3, LOW);
  digitalWrite(motorPin4, LOW);
  delay(delayTime);
void blink() {
 digitalWrite(ledPin,HIGH);
 delay(10);
 digitalWrite(ledPin,LOW);
 digitalWrite(motorPin1, LOW); // Primer paso
 blink();
 delay(delayTime);
 digitalWrite(motorPin1, LOW); // Segundo paso
 blink();
 delay(delayTime);
 digitalWrite(motorPin1, LOW); // Tercer paso
 blink();
 delay(delayTime);
 digitalWrite(motorPin1, LOW); // Cuarto paso
 blink();
 delay(delayTime);
 digitalWrite(motorPin1, LOW); // Quinto paso
 blink();
 delay(delayTime);
 digitalWrite(motorPin1, HIGH); // Sexto paso
 blink();
 delay(delayTime);
 digitalWrite(motorPin1, HIGH); // Septimo paso
 blink();
 delay(delayTime);
 digitalWrite(motorPin1, HIGH); // Octavo paso
 blink();
 delay(delayTime);
pd: Dip is an ULN2003A
diagram
and finally I connected motor to (550W) ATX power. (Yellow, Black)
http://arduinadas.blogspot.com/
MarkT
What is the chip on the breadboard?  What is the power supply for the motor?  Schematic? Decoupling?
miniduino
The chip on the breadboard is an ULN2003A and de power supply is an ATX. Conected at pin 12v and ground.
Grumpy_Mike
The red wire should be at the 12V.
Do you see or feel the motor become stiff and does it make a buzzing noise when you try and drive it?
If so you should slow down the speed you are trying to drive it and try swapping the coil motor wires around to get the sequence right.
justone
You will also need to hookup pin 9 of the ULN2003 to de power (plus side of course) or you will blow out the drivers (which you may already have).
Pin 9 is the common return for the internal diodes. Google will ...
