Topic: Getting reliable Serial.read()'s without a stop character (Read 5820 times) previous topic - next topic
antiquekid3
Hey guys, I've been playing around with a command interpreter I recently wrote. I found that if I didn't add a delay when processing new Serial data, my new Serial data might come in two separate chunks, or more. As one person mentioned before, adding the delay is a "band-aid" solution to the problem. Here's a way I found that will prevent that reliably, though it may still be seen as a crutch to the program. I'd love some feedback on this. Thanks! Oh, and I hope the comments don't get in the way...they are supposed to be there to help, but who knows if they will or not.
Code: [Select]
  //let's start by starting some serial communication
  Serial.begin(57600);
//then initialize some needed variables here...
//character array to store the command
char command[30];
//index for character array
int i = 0;
//lets us know if a command is available to be processed or not
boolean commandAvailable = false;
//how many times will the program check to see if serial is
//available from the buffer before flagging the command as read?
#define TRIES 50
//a variable that will be used again and again for checking the above
int tries = TRIES;
  //check if serial is available and that we haven't exceeded the number of tries
  //and that we haven't gone past the size of the command
  if (Serial.available() > 0 && tries > 0 && i < sizeof(command))
    command[i++] = Serial.read(); //store a byte in the array, then increment the index
    commandAvailable = true; //a command will eventually be ready...
    //we will keep checking for data at the buffer for <code>TRIES</code>
    //number of times until we are convinced there is no more data to be read at this time.
    tries = TRIES;
    //we either:
    //1. didn't find any data at the buffer, or
    //2. we've exceeded the command size, or
    //3. we have looked for data an appropriate number of times.
    //Thus, we need to decrement <code>tries</code> to say that we've looked
    //for data yet another time.
    tries--;
  //if we have a command available and we have reached zero
  //indicating we have looked for data <code>TRIES</code> number
  //of times, we are ready to see the command.
  if (tries <= 0 && commandAvailable)
    //let's get rid of all that other data in case the buffer still has some left in it.
    Serial.flush();
    //print out the command we received
    Serial.println(command);
    //reset the index for the next time
    i = 0;
    //reset the number of tries for next time
    tries = TRIES;
    //confirm that we've checked the command, so mark this false
    //write over the command space so we don't see previous characters
    //for a shorter command next time
    for (int i = 0; i < sizeof(command); i++)
      command[i] = 0;
PaulS
Code: [Select]
    Serial.flush();
Why?
Code: [Select]
      command[i] = 0;
Lovely. Insert NULLS in every position because you don't understand what NULL-terminated means.
How fast does loop() operate? Let's assume that no serial data is sent.
1) Check for serial data (Serial.available() gets called. It computes and returns the difference between two pointers - two uint8_t accesses and a subtraction operation).
2) Compare the result to 0. It's not greater, so
3) Decrement tries (an int access, a subtract, and an int store)
4) Another if test with an int access, a compare, a byte access and another compare
How long do you think this will take to execute? I'll wait while you figure it out. Remember the Arduino operates at 16MHz, so each operation takes 62.5 nanoseconds.
Quote
It is.
jraskell
Your 'tries' method really just boils down to another form of delay, just a non-blocking (and rather convoluted) version.
What do you see wrong with utilizing a stop character?
antiquekid3
Paul, you are coming off as rude, to be honest. I am not a professional programmer, and I'm not calling myself one. As a college student who got into Arduinos a couple of years ago with the Diecimila, I would recommend encouraging new people instead of making them feel/look stupid. Just my two cents.
Why am I flushing out the buffer? Well, I figure that for my purposes, each of my commands would be no longer than thirty characters. Any leftovers in there would be read on the next round and added to the first, but please let me know if I'm missing something here.
I had never even realized C and other languages terminate a string with /0 before you mentioned it. If that's the case, then I'd expect I really don't need to overwrite my character array. Thanks for the tip!
If the Arduino could grab the entire serial data from the computer at one time and store it in the buffer, you could read the buffer one time and one time only. However, it doesn't do that apparently. Since the Arduino cannot accurately guess the length of the next command it receives (arbitrary length in my case, obviously), there doesn't seem to be a "good" way of solving this problem unless you add a stop character. I don't want to add a stop character since my command interpreter is being used directly from a terminal, and that's just one more thing for the user to type, every single time. Could I write a front end for the program to add a stop character? Sure, but that is just more work and it wouldn't be as portable. I wanted this Arduino to be able to run from any modern computer with USB and a terminal program. A stop character seems more like a crutch to me, especially if your Arduino is not having to do a lot of processing. My needs required it to turn on and off a few relays. Not too hard. Thus, I was hardly worried about efficiency except for the ease-of-use for the user.
I agree, this code is not good for programs that require speed. But this seemed to work for me.
nickgammon
It's a streaming protocol. It's nothing to do with the Arduino.
That is, there is no inherent way of saying "a command has arrived". Looking for pauses or "it it all arrived in 10 mS it must be a command" is just flaky.
The way things have worked for a long time is that the newline character (generally) is the "end of command" character. So you type "start motor \n" where \n is the newline you get when you press the Enter key. That's your stop character.
So all you have to do in loop is have a reasonable size buffer. Check if Serial.available () is not zero, and if so, get the next character with Serial.read (). If that happens to be a newline then that is your "stop character" and you process the previous command (and then empty out the previous command). If not, you append it to your buffer, checking you don't overflow how much you allocated.
Some systems have a "each key is a command" system where each time you type something, it is interpreted. Of course that tends to limit you to single-character commands.
I agree with Paul that you don't want to flush every time, that is just throwing away pending information. What that is like is opening your email program, deleting everything in your inbox, and then sitting back and waiting for mail. Too bad if mail arrived before you opened the mail program, you just deleted it.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
PaulS
Quote
Wasn't my intention.
Quote
I figured that out. Right away.
Quote
Then you should be dumping, unread, no more than 29 characters, not the potentially 127 characters in the buffer.
Quote
Perhaps you should have paid better attention in class. (Now, I am moving closer to that "rude" line, just so you know the difference). This is pretty fundamental.
Quote
Here's your same "packet" without stop markers:
Quote
IftheArduinocouldgrabtheentireserialdatafromthecomputeratonetimeandstoreitinthebufferyoucouldreadthebufferonetimeandonetimeonlyHoweveritdoesn'tdothatapparentlySincetheArduinocannotaccuratelyguessthelengthofthenextcommanditreceivesarbitrarylengthinmycaseobviouslytheredoesn'tseemtobea"good"wayofsolvingthisproblemunlessyouaddastopcharacter
Nowhere near as easy to read, is it?
Quote
From what terminal? The Serial Monitor with 0022 has the ability to add end-of-packet characters automatically.
Quote
I guess we'll just have to agree to disagree.
Quote
Don't forget that you'll need to install the necessary drivers for whatever Arduino you are using.
Quote
You could do this with one letter per relay. Use a capital letter for on, and a lower case for off. Then, each command is exactly one letter long, and you don't need a crutch. I mean end-of-packet marker.
graynomad
If your incoming data is of a variable length you have two choices
a) Decide that after a certain time with no characters received you parse the command (dodgy and not even remotely good with user input).
b) Use an end character.
As just about every human keyboard interface in history has used a CR and/or LF to determine the end of a command I can't see what the problem is with doing the same, it's second nature to go "type type type return".
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
hickscorp
i had a similar problem years ago, and if i remember well, i had to create a very simple protocol, which was making each transmitted frame beginning with a length char. i had to do that because a single frame could potentially contain any value, including the stop character. So basically, what i did was something like that (In pseudo code):
Emitting end point:
- Check size of data to be sent.
- Send this size (You have to choose wether this size is stored as byte, word, etc based on the max length of the data you would transmit).
- Send the real data, with no termination packet.
Receiving end point:
- Poll data until you have the size (If you're using a byte, poll just one byte, if you're using a word, poll two bytes and assemble them knowing which one is LO / HI).
- Then loop-poll data for the size you just got. You don't have to test for a terminator.
i don't know if this would work on the Arduino, maybe this would be a mistake, but i will for sure try it when i'll start playing with serial devices.
Pierre.
PaulS
Quote
Serial data delivery is not guaranteed. Bytes can get lost. What happens if one of the bytes is part of your length data? You get a wrong length, of course. Then, you can never get back in sync.
hickscorp
#9
Oct 20, 2011, 02:59 pm Last Edit: Oct 20, 2011, 03:01 pm by hickscorp Reason: 1
Quote
You're right. So i would establish a small protocol like that.
byte 0 to 3: size of packet (1 byte), expected checksum also used as end delimiter (2 bytes).
byte 3 to n+3: packet (n bytes).
byte n+3 to n+5: delimiter again (2 bytes).
In case of a loss of sync, the detection is easy. Jumping back in sync is a matter of considering each received byte as a starting point again, until incrementally we reach a matching size / delimiter pair on both ends (At most, one whole packet would be dropped while re-syncing, assuming that there was no loss in the next transmission). Right?
PaulS
Quote
Right?
Yes, but by the time you add all this stuff, converting the data to send to ASCII and sending strings is much simpler.
hickscorp
Right PaulS.
Out of curiosity, how would you send ASCII data (Null terminated) for a range of required values going from 0 (included) to 255 (Included)? Would i have to arbitrarily remove a value from this range (So only 255 different values can be sent) and use the arbitrarily chosen value as a delimiter?
AWOL
PaulS
Quote
I'd send "<0>", "<1>", "<2>", ..., "<253>", "<254>", "<255>". That's ASCII data, including start and end markers, for all values from 0 to 255.
hickscorp
#14
Oct 20, 2011, 04:14 pm Last Edit: Oct 20, 2011, 04:16 pm by hickscorp Reason: 1
Quote
Hm. i didn't picture it like that. Isn't that a waste of Arduino CPU power decoding the data when consequently heavy?
To get a single byte of data, you have to send a minimum of 3 bytes, and a maximum of 5 bytes? So your frame length is n*3 <= real data length >= n*5 ?
Why not directly sending something like that according to your example values:
0x00, 0x01, 0x02, ..., 0xfd, 0xfe, 0xff, 0x00, 0x00 ?
So your frame length = nBytes+2, and your delimiter is a 0x00 pair? Is it again related to the data loss fact? What ratio of loss is observable in real-life circuits over a reasonable length of wire?
