Topic: Linux Kernel 3.0 stopped ArduinoISP working (Read 15499 times) previous topic - next topic
kfreak
#45
Jan 16, 2012, 10:48 pm Last Edit: Jan 16, 2012, 10:56 pm by kfreak Reason: 1
I hooked up the arduino ISP to a 2 Channel Oscilloscope. Duemilanove board with Uno chip as ISP, and Uno board as target. I had a computer running a 2.6 kernel and arduino 021, and one with ubuntu 11.10 with 3.0 kernel. AVR compiler from repository.
In short my findings:
Arduino ISP (021, 2.6)Arduino ISP (1.0, 3.0)
linux 2.6 control computer, 021
success (0, 1)
fail (6)
linux 3.0 control computer, 1.0
success(2,3)
fail (4,5)
attached are the traces. The number in brackets in the table above correspond to the trace filename. The oscilloscope is an Agilent without an digital capture option. I used the reset as a trigger, channel two is one of the data connections between the boards.
I did not have a close look at the traces yet, but something must go wrong after initial negotiation.
It seems that you need to compile and upload the ISP sketch using 2.6. This can then be used on a 3.0 kernel system. So keep one spare atmega328 as ISP around.
kfreak
more traces. Seems I forgot to save trace 7, but nothing impressive there.
kfreak
Getting an
Code: [Select]
avrdude: error while loading shared libraries: libusb-0.1.so.4: wrong ELF class: ELFCLASS64
when trying to copy the ISP. Don't have time to debug this now.
But I remember that I tried with a different version (023?) on 3.0 before and it failed.
madworm
Well, as others, I still believe it is a compiler / toolchain issue. It would be interesting if you could install a 3.0 kernel on your older 2.6 system (the one with a working toolchain).
If the kernel of an OS actually had an influence on the outcome of a compilation run... that would be hilarious / insane / madness...
I could understand if the actual transmission were broken (serial driver issues).
maniacbug
In fact, we can presume it's a toolchain problem, and that the kernel rev is a red herring.  No evidence has been presented that it has anything to do with the kernel.
kfreak
I cannot install a 3.0 kernel on my 2.6 machine without dist-upgrade, which I don't want to do at this moment.
Would it help to post the .hex of the working sketch? Or do you need file versions? I can zip all the avr-relevant files and upload somewhere. (but maybe binary, which would be of little help)
leo72
I tried a similar test when I used Arch Linux. I installed a kernel from 2.6 branch but got the same errors.
maniacbug
I found a reasonable work-around for this problem.  This now works for me on Ubuntu 11.10 64-bit, where it did not previously, simply by changing the baud rate to 9600. Also it works to change the SERIAL_BUFFER_SIZE to 72 in HardwareSerial.cpp.
It seems that the ISP is hanging in fill() getting a buffer overrun.
leo72
Sorry, but where did you change the serial speed to let the ArduinoISP sketch working?
maniacbug
Line 69 in https://github.com/rsbohn/ArduinoISP/blob/master/ArduinoISP/ArduinoISP.ino
and
Line 35 in https://github.com/maniacbug/mighty-1284p/blob/master/bootloaders/optiboot/Makefile
