Topic: PWM not working correctly - pls help. (Read 2507 times) previous topic - next topic
unknow050
Oct 22, 2011, 08:25 am Last Edit: Oct 22, 2011, 08:37 am by unknow050 Reason: 1
Hello,
I am using PWM (pin 3) for fade in and fade out of multiple LEDs connected behind transistor (I even try connect LED directly to pin 3).
analogWrite(3, 0); = LEDs are turned off
This work good but when I incremet value to: analogWrite(3, 1); , all LEDs start shine maybe on 50%!! Is it possible to change PWM so all LEDs start shine on 1 - 5 %???
I am using high brightness LEDs (50cd). I even try lower brightness but all time I can control my LEDs from OFF/50% to 100%.
Thank you.
(sorry for my bad language)
johnwasser
My first guess would be that there is a capacitor in the circuit that is stretching the pulses and causing the transistor to conduct even after the output has been turned off.  Another possibility is a software error.  Is Pin 3 set as an output?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
unknow050
capacitators are not in my scheme. Even if I connect one LED diode with resistor to Arduino and set analogWrite(3, 1);, LED start glow high (cca 50% of max). I tryed this:
cyc:
digitalWrite(3, TRUE);
delaymicroseconds(1);
digitalWrite(3, false);
delay(20);
goto cyc;
LED glow just a little (cca 5% of max). But it is hard to control fade in and out with this way. I read something about 10kHz PWM etc. Is it possible to "slow" PWM? Or have someone another tip?
Thank you.
dc42
Please post your schematic and your sketch, then we may be able to tell what is wrong.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
unknow050
#4
Oct 23, 2011, 03:48 am Last Edit: Oct 23, 2011, 03:55 am by unknow050 Reason: 1
I am sure scheme is ok. Code looks good too. I tryed to slow down fade in and out and it looks that "fade out" of all LEDs are smooth (LEDs brightness slow from 100% to 0% better but "fade in" is jumped to 50% and than slowly increase to 100%. I tryed even different LEDs. I think PWM is set fast so what is default rate of PWM at Arduino? 10kHz? 1kHz? Maybe if I will change it to lower setting ... ??? Thanks for tips.
Code:
int tlacitkoMaska = 0;         // button value
int hodnota = 1;                 // PWM value
 pinMode(3, OUTPUT);      // PWM
 pinMode(7, INPUT);         // button
zacatek:
 analogWrite(3, hodnota);                    // PWM pin 3
 for (int c=0; c <= 50; c++) {                 // testing button here (50*20ms = 1sec)
   tlacitkoMaska = digitalRead(7);
   if (tlacitkoMaska == HIGH) {
     goto preruseni;
   delay(20);
 analogWrite(3, 0);                               // PWM pin 3
 for (int c=0; c <= 100; c++) {                // testing button here (100*20ms = 2sec)
     goto preruseni;
   delay(20);
 if (hodnota < 255) hodnota = hodnota + 1;    // increase brightness of LEDs here
 goto zacatek;
preruseni:
 analogWrite(3, 0);                  // turn off leds here
 hodnota = 1;                           // reset PWM to value 1
 goto zacatek;                         // goto beginning
dc42
I can't see why your sketch isn't working, but I have a few observations:
- Please use the # button when posting code, it makes it easier to read
- You should use a separate series resistor for each LED, not one common resistor. This is because LEDs can't be guaranteed to be sufficiently close to identcal to share the current well when connected in parallel.
- Your code is full of goto statements, which make it hard to understand. Try to rewrite it without using goto.
- You haven't shown how the button is wired in your schematic, nor have you said whether it is pressed or not when the fade-in is supposed to be happening. So I can't rule out contact bounce as a possible cause.
- Be careful of using Darlington transistors, especially when the supply to the load being switched is only 5v. Darlingtons are #4 in my Arduino "do not use" list, http://miscsolutions.wordpress.com/2011/10/16/five-things-i-never-use-in-arduino-projects/.
unknow050
Thanks dc42 for reply.
button in scheme is not necessary and I can not use resistor for each leds in my project. In darlington is not problem too, because I even try conect one LED with resistor directly to PWM output and all LEDs do same....
I found this:
http://www.youtube.com/watch?v=BEihknGUA_8
LED looks good, it work for this guy and he even increasing PWM value by 5!. May I have broken Arduino?
johnwasser
The code looks like it should work.  I think the problem must be in the hardware.
Code: [Select]
const int ButtonPin = 7;
const int OutputPin = 3;
  pinMode(OutputPin, OUTPUT);      // PWM
  pinMode(ButtonPin, INPUT);         // button
  while (digitalRead(ButtonPin) == LOW)
    analogWrite(OutputPin, hodnota);  // Set brightness
    // One second ON
    for (int c=0; c < 50; c++)
      if (digitalRead(ButtonPin) == HIGH)
      delay(20);
    analogWrite(OutputPin, 0);                               // PWM pin 3
    // Two Seconds OFF
    for (int c=0; c < 100; c++)
      delay(20);
    if (hodnota < 255)
  analogWrite(OutputPin, 0);                  // turn off leds here
unknow050
Thanks John for code ... It looks nice but I like goto because it looks "easier to understend" for me.
I will borrow another Arduino from my friend and try it.
Thx all.
3dprinter
I had a "HighPower" LED and it was bright even at PWM value 3. If I used an oldfashined weak indicator LED the fading worked fine, and the LED basically didnt appear lit before value 20 or so. I tried then to view the power-LED in strong light, and the dimming effect was "better".
the new poerLEDs are simply too good :)
(NB: I havent looked at the code - the others have done that)
bensoibj
#10
Oct 25, 2011, 02:47 pm Last Edit: Oct 27, 2011, 04:13 pm by bensoibj Reason: 1
The problem is that it's not a good idea to control the brightness of a LED by varying its voltage.
Take a look at the attached exemplary datasheet, which is taken from a warmwhite LED from Nichia. As you can see from the right figure, the brightness depends nearly linear on the current. That is, if you increased the current from 0 to max, the brightness of the LED would fade in the same way.
The left figure shows the dependency of the current on the voltage. It is an exponential one! This means, even if you increase the voltage only a little bit, the current increases very quickly - and so does the brightness. This is what you are doing with your circuit. The resistor in series to the LED linearizes the behavior a little, but the better way is to use a current source which is controlled by a voltage. There are lots of examples in the internet.
All the theory would be negligible if the PWM pulses were nicely shaped rectangle pulses. Then the voltage would pulse the current and so the brightness. But, as posted by johnwasser, capacitors can screw up the game. Even if you not use any, there are always parasitic ones. And then you have to cope with the nonlinear behavior of the current.
And, as posted by dc42, LEDs should not simply be connected in parallel, at least not if you want them to have the same brightness. Connecting them in parallel, you force all LEDs to have the same voltage. Because of the steep slope of the current curve together with slight differences in the characteristics of each LED, the resultant currents and thus the luminosities might differ. If you instead connect the LEDs in series, all of them will have the same current, but then the voltage has to be sufficient high.
unknow050
