Topic: Unable to upload to ArduMini (Read 1 time) previous topic - next topic
AlessandroM
Hi!
After many succesful projects with 2009, uno and mega I've tried to use Arduino Mini Light for the first time but I have a problem uploading software:
I get this error:
Code: [Select]
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Connections seem to be correct:
Also Board type and port are correct.
Anybody can help me?
Thanx in advance!
Alex
BillO
You need to add a reset button between ground and one of the reset pins on the mini.
Click the upload button the the software then when the size message appears, press the reset button.
lyron
Or hook up the reset pin on the arduino to the reset pin on the programmer
Royly
Have a look at this. You need to hook up the reset pin to the RTS pin on the USB-TTL board - http://protopicelectronics.wordpress.com/2010/11/26/getting-the-arduino-pro-mini-328-5v16mhz-to-work-with-the-arduino-serial-usb-board/
BillO
That's a pro mini in that video article.  The mini does not have the .1uF capacitor for the reset.
You could add it though.  Connect one lead of the .1 cap to the reset input of the mini, then connect the other end of the cap to DTR on the USB-TTL (RTS might also work, but DTR is the standard).
AlessandroM
sorry for the delay but...thanks! your suggestions about the reset solved the problem.  :)
