Topic: Sleep code for the 2560 (Read 7623 times) previous topic - next topic
tubular
does something need to be modified for the sleep code from the arduino site to work with the mega2560?
http://www.arduino.cc/playground/Learning/ArduinoSleepCode
Code: [Select]
#include <avr/sleep.h>
/* Sleep Demo Serial
* Example code to demonstrate the sleep functions in an Arduino.
* use a resistor between RX and pin2. By default RX is pulled up to 5V
* therefore, we can use a sequence of Serial data forcing RX to 0, what
* will make pin2 go LOW activating INT0 external interrupt, bringing
* the MCU back to life
* there is also a time counter that will put the MCU to sleep after 10 secs
* NOTE: when coming back from POWER-DOWN mode, it takes a bit
*       until the system is functional at 100%!! (typically <1sec)
* Copyright (C) 2006 MacSimski 2006-12-30
* Copyright (C) 2007 D. Cuartielles 2007-07-08 - Mexico DF
*  This program is free software: you can redistribute it and/or modify
*  it under the terms of the GNU General Public License as published by
*  the Free Software Foundation, either version 3 of the License, or
*  (at your option) any later version.
*  This program is distributed in the hope that it will be useful,
*  but WITHOUT ANY WARRANTY; without even the implied warranty of
*  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*  GNU General Public License for more details.
*  You should have received a copy of the GNU General Public License
*  along with this program.  If not, see <http://www.gnu.org/licenses/>.
int wakePin = 2;                 // pin used for waking up
int sleepStatus = 0;             // variable to store a request for sleep
int count = 0;                   // counter
void wakeUpNow()        // here the interrupt is handled after wakeup
  // execute code here after wake-up before returning to the loop() function
  // timers and code using timers (serial.print and more...) will not work here.
  // we don't really need to execute any special functions here, since we
  // just want the thing to wake up
  pinMode(wakePin, INPUT);
  /* Now it is time to enable an interrupt. In the function call
   * attachInterrupt(A, B, C)
   * A   can be either 0 or 1 for interrupts on pin 2 or 3.
   * B   Name of a function you want to execute while in interrupt A.
   * C   Trigger mode of the interrupt pin. can be:
   *             LOW        a low level trigger
   *             CHANGE     a change in level trigger
   *             RISING     a rising edge of a level trigger
   *             FALLING    a falling edge of a level trigger
   * In all but the IDLE sleep modes only LOW can be used.
  attachInterrupt(0, wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
                                      // wakeUpNow when pin 2 gets LOW
void sleepNow()         // here we put the arduino to sleep
    /* Now is the time to set the sleep mode. In the Atmega8 datasheet
     * http://www.atmel.com/dyn/resources/prod_documents/doc2486.pdf on page 35
     * there is a list of sleep modes which explains which clocks and
     * wake up sources are available in which sleep mode.
     * In the avr/sleep.h file, the call names of these sleep modes are to be found:
     * The 5 different modes are:
     *     SLEEP_MODE_IDLE         -the least power savings
     *     SLEEP_MODE_ADC
     *     SLEEP_MODE_PWR_SAVE
     *     SLEEP_MODE_STANDBY
     *     SLEEP_MODE_PWR_DOWN     -the most power savings
     * For now, we want as much power savings as possible, so we
     * choose the according
     * sleep mode: SLEEP_MODE_PWR_DOWN
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);   // sleep mode is set here
    sleep_enable();          // enables the sleep bit in the mcucr register
                             // so sleep is possible. just a safety pin
    /* Now it is time to enable an interrupt. We do it here so an
     * accidentally pushed interrupt button doesn't interrupt
     * our running program. if you want to be able to run
     * interrupt code besides the sleep function, place it in
     * setup() for example.
     * In the function call attachInterrupt(A, B, C)
     * B   Name of a function you want to execute at interrupt for A.
     *             LOW        a low level triggers
     *             CHANGE     a change in level triggers
     *             RISING     a rising edge of a level triggers
     *             FALLING    a falling edge of a level triggers
    attachInterrupt(0,wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
    sleep_mode();            // here the device is actually put to sleep!!
                             // THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
    sleep_disable();         // first thing after waking from sleep:
                             // disable sleep...
    detachInterrupt(0);      // disables interrupt 0 on pin 2 so the
                             // wakeUpNow code will not be executed
                             // during normal running time.
  // display information about the counter
  Serial.print("Awake for ");
  Serial.print(count);
  Serial.println("sec");
  count++;
  delay(1000);                           // waits for a second
  // compute the serial input
  if (Serial.available()) {
    int val = Serial.read();
    if (val == 'S') {
      Serial.println("Serial: Entering Sleep mode");
      delay(100);     // this delay is needed, the sleep
                      //function will provoke a Serial error otherwise!!
      count = 0;
      sleepNow();     // sleep function called here
    if (val == 'A') {
      Serial.println("Hola Caracola"); // classic dummy message
  // check if it should go to sleep because of time
  if (count >= 10) {
      Serial.println("Timer: Entering Sleep mode");
      count = 0;
It has always worked fine with my duemilanove but doesnt want to work with the mega2560
thanks
nickgammon
It doesn't sleep or it doesn't wake? How have you got pin 2 wired? Through an external pull-up?
You should really detach the interrupt in the ISR - although I know this is probably stock sample code.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
tubular
It wont sleep, so I havent even gotten to the interrupt yet
nickgammon
You didn't respond to my question about the wiring.
I enabled the pull-up like this:
Code: [Select]
  digitalWrite (wakePin, HIGH);
Then (on the Mega 2560) it worked fine:
Code: [Select]
Awake for 0sec
Awake for 1sec
Awake for 2sec
Awake for 3sec
Awake for 4sec
Awake for 5sec
Awake for 6sec
Awake for 7sec
Awake for 8sec
Awake for 9sec
Then grounding pin 2 woke it up.
tubular
ok I that worked thanks I added
Code: [Select]
michaelproino
Hi, I ask a question about this code, in this line :
"use a resistor between RX and pin2"
What is the value of the resistor there mentioned? Does it means short circuit, else what?
