Topic: probably just a simple silly error, im a newb... (Read 2537 times) previous topic - next topic
howellrh
In trying to write a program , I'm using the analog to run a thermistor, this will be calibrated later using resistors etc and getting the value right (it probably wont be 90), but i keep getting the same errors...
below is my code:
// program for egg boiling timer. timer starts when water temp reaches boiling. flashes yellow when soft boiled, then fades into red, and flashed red when hard boiled
int red     = 9;             // Digital pin 9 - Red LED
int yellow    = 10;          // Digital pin 10  - Yellow LED
int time    = 5;             // time/delay
int pulsewidth;              // pulsewidth value (0-255)
int analog;                  // declare an integer variable first
                             // using analog pin 0 for thermistor potential divider
byte x;
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  digitalWrite(9, LOW);
  digitalWrite(10, LOW);
  analog = analogRead(0);    // read voltage on channel 0 and store it in variable
  if(analog<90){
  else{
delay(180000);               //delay 3 mins
void loop() {                //flash yellow LED for 5 seconds at 4Hz to signify soft boiled
  if(x>19){
   digitalWrite(10,HIGH);
   delay(250);
   digitalWrite(10,LOW);
   delay(250);
x++;
else{
  // slowly fade the red LED to full brightness, yellow to 0
  for (pulsewidth=0; pulsewidth <= 255; pulsewidth++){
    analogWrite(red, pulsewidth);
    analogWrite(yellow, -pulsewidth);
    delay(time);
   digitalWrite(9,LOW);        //reset both LEDs
  void loop() {                //flash red LED for 5 seconds at 4Hz to signify hard boiled
  if(x>19){
   digitalWrite(9,HIGH);
   delay(250);
   delay(250);
x++;
else{
##############################################END OF CODE#################################################
and my errors are as follows:
egg_timer_1.cpp: In function 'void loop()':
egg_timer_1:27: error: a function-definition is not allowed here before '{' token
egg_timer_1:65: error: expected `}' at end of input
PLEASE HELP :)
other useful info (maybe), I'm using the "arduino duemilanove or Nano w/ ATmega 328" board
rich x
CrossRoads
You have void loop() in there four time - you can only call it once.
Click your cursor next to each }, then use the scroll bar & look back in the code to see if the mating { is in the right place.
Clicking CTRL-T (autoformat) will also help you catch things like that.
howellrh
hi CrossRoads
can I not have loops inside loops then? if so how can I make my program wait and only start when analog is more than 90?
CrossRoads
Question 1: You can  have nested for:next loops, or nested while loops, or nested functions.
You just can't call all the functions "void loop()", that has special meaning to the compiler.
Question 2:
while (analogRead(0) <=90){
// hang out here
howellrh
cool, I tried that, so I basically I replaced all the void loops with while code, because I wasn't using the else bit at all, I was using them all for the same, and that way none of them are inside each other.
So, this is what it looks like now...
byte x;
  pinMode(9, OUTPUT);
// wait for it...
  while (x<19){              //flash for 5 sec to show egg is soft boiled
   delay(250);
   delay(250);
   x++;
x=0
    delay(time);
   while (x<90){        //flash red LED for 5 seconds at 4Hz to signify hard boiled
   delay(250);
   delay(250);
   x++;
else{
##########END
with errors:
egg_timer_1:1: error: expected unqualified-id before numeric constant
egg_timer_1:21: error: expected unqualified-id before 'while'
egg_timer_1:25: error: expected constructor, destructor, or type conversion before '(' token
egg_timer_1:28: error: expected unqualified-id before 'while'
egg_timer_1:37: error: expected constructor, destructor, or type conversion before '=' token
sorry I'm such a pain!
rich
CrossRoads
You need to check your use of { }s
All the code that is not a function (i.e. void something_or_other() )
needs to fit within
// code here runs once
or
// code here repeats
You have code that is not a function and is not in either required function (setup & loop).
howellrh
Ahh, I see, I've redone a lot of the code and it now compiles fine :)
thank you so much CrossRoads!  :D
rich
CrossRoads
